200+ woodworking book reviews
nut cracker
nut cracker
nut cracker
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA
>My son and daughter-in-law asked be to make them a nut cracker that works with a screw thread. I happen to have the Beal threading system, so I know I can, in principle, do it. But I could use some design ideas. Any thoughts?
Re: nut cracker
Giant "C" clamp???
>Just a thought. I am actually somewhat serious. You would need a large base (tray) to collect pieces and parts - maybe even a lip. Another "weird" thought - how about something "A" shaped or vaguely "trapezoidal" - with the screw going through the center to a round piece with an "anvil" below.
Re: nut cracker
Re: nut cracker *LINK*
>I've seen some that consist of a bowl shape, large enough to take the nut, with a screw thread coming in one side. The ones I've seen have the screw thread coming in along the grain, so the force of the thread is less likely to crack the "bowl."
The design is similar to the nut splitters mechanics use when a nut is so frozen in place that a wrench won't budge it - see link below for an example - but with a bowl around the nut to keep the bits in place.
like this linky, but with a bowl around it
Re: nut cracker
Re: nut cracker
Carol Reed - home in Strawberry
>If you look at the Beal Tool Company's threader, you will see in the background of the picture a nutcracker. It looks like a little house with an opening and a knob on top. Fits in your palm. That ought to give you another idea.
Re: nut cracker
Re: nut cracker
Gary Camp, Bend, Oregon
>I made a nut cracker with a Beal threader by cuttingn out about a 6 inch circle of 6/4 maple and holesawing out the center with a 3" hole saw, cut a flat on one edge and the threads on the other. it worked pretty good.
glc
Re: nut cracker
Re: nut cracker
Lewis Dodd-aka-- RIPSAWED
>Well, we got a lot of NUTS down here in Texas and some are easy to crack and some are almost impossible to crack!
Seriously, for cracking pecans, you cannot beat the "Texas inertia" cracker. It has no threads and uses rubber bands. We have tried them all and it is eons above the rest! Can't say about the brazil nuts, but works well on walnuts, pecans, filberts,almonds and hazelnuts!
Lewis
Re: nut cracker
Re: nut cracker
>I always figured that, in Texas, you just stepped on it with the heel of your cowboy boot - no?
