Dados with a router question.
Ray Carson - Lawrenceville, NJ
>Simple enough, right. Is there any benefit or tradeoff in using certain bits?
First being a straight up and down two bladed type. Second would be a spiral down cut. Third would be a spiral up cut. Second and third bits are 1/2" solid carbide. First bit is a 1/2" bit with two carbide blades mounted on a steel shaft.(typical stuff) I'm using a homemade jig that my router will slide in. Similar to something you'd see for making the slots for a louvered door panel on a bias to the grain. I'm cutting into the face grain. I'm using Red Oak.
Thank you,
Ray
