OT File in UDF Format
T Rex
>I received a CD from my nephew.
When I put it in my cd drive I got the message that it couldn't read a UDF file.
Do you use UDF?
What do you use to read the file?
Have you ever used UberDownloads?
They say that I can download a program that will read UDF.
I don't like to download stuff from sites I don't know.
Thanks,
T Rex
Re: OT File in UDF Format
Gil Jones...GA
>I have not had any problems with Cnet downloads.....ymmv??
http://download.cnet.com/Adaptec-UDF-Reader-Driver/3000-2100_4-10021086.html
Also:
Roxio Software Updates
The UDF Reader is already included as a part of your Roxio Easy CD ... Once installed, you do not need to take any special steps to activate the UDF Reader; ...
www.roxio.com/enu/support/udf/software_updates.html - Cached - Similar
John McGaw
>The free Nero In-CD Reader program will also allow the reading of UDF disks.
Alex Grigoriev
>Windows XP and up supports UDF reading. Did you put the disc to a non-PC device?
Tom Rex in TX
>I went to the Microsoft site & it said I had to have SP3.
I wanted to back up my data before I downloaded updates to my system.
I was hoping to find an easier fix.
victor parisian
>I have never felt the need to back up files before MS updates. Should I have reason to be concerned?
I've been using personal computers since CPM was about the only option for an operating system. 48k of memory upgraded to a whopping 64k and two 8 inch floppy disks.
Victor in Houston
Dan Donaldson
>It doesn't happen too often, but especially on an sp-x update, the process will hiccup once in awhile and you could lose everything. There are states during the upgrade where the system may not be viable if anything goes wrong at all. Fairly low risk, but catastrophic if it happens.
Tom Rex in TX
>Even Microsoft recommends it.
Most other software does also.
I used to write the install programs for software that my compnay developed.
Maybe I'm paranoid but I don't trust nobody.
