Lacquer & Muscle cramps ? ? ?
Pete in Holland, MI
>Guys -
Not sure if this has happend to anyone else or not.
I have been working this past week on a series of wood games for to be donated to a chariatable organization for Christmas presents for the needy. Due to the quantity of the games and the desire for 2 coats of finish, I opted to use a lacquer-based varnish that dried quickly. Due to the shape of the toys, brushing the finish on my fingers was going to be part of the process that couldn't be avoided. I have a small exhaust fan operating in my shop, and a small fan to blow some of the lacquer fumes from me as much as they can.
Within an hour, the muscles on either side of my spine started to tense up. Within another hour, I had to stop working. I cleaned my hands & went up stairs, took some meds and curled up with a heat pad. I was thinking this was a result of my standing and stooping that evening.
The next afternoon, I started the process again. Within an hour, the pains returned. I quit for a few hours and came back to finish the first coat as soon as I could.
Later that evening, as I was feeling better, I steel-wooled the projects (125 games, by the way) with no indicent.
When the second coat was applied later that night, 2 things changed:
1) The window on the opposite end of the shop was cracked open to allow make-up air for the exhaust fan to draw from (even though it was 20F outside).
2) A tool was made to hold the puzzles so my hand contact with the finish was eliminated.
The result?: No issues with my health.
Fuzzy conclusion: I feel it was my hand drawing in some of the chemicals in the finish, reacting with the muscles in my back. I didn't feel any other symptoms.
The following day, I worked on the puzzles and never had another health issue. I feel fine now.
Has this ever happened to anyone else? Am I drawing conclusions without enough evidence? Yes. I know. I should have been wearing a glove.
Thanks . . . .
Pete
Re: Lacquer & Muscle cramps ? ? ?
>Cramps aren't listed as an effect of exposure in the one MSDS sheet I looked at, but it does list possible nerve and brain damage. Not to be messed with.
It sounds like you've done enough experimentation on yourself to adopt stronger safety practices. Regardless of whether or not the cramps were caused by the lacquer or lacquer thinner, this is a substance that calls for good safety practices to protect yourself. Google "lacquer msds" for examples.
Yes, yes, on the ventilation, and you should be wearing gloves - but the one chart I looked at says that resistance to lacquer is poor for all common glove types (latex, nitrile, neoprene). So better would be finding a way not to have to touch the toys or work being lacquered - set them on nails on a board or something. A respirator would be a good idea, too, especially this time of year, when good ventilation is harder in most climates.
Re: Lacquer
>Will kill you if you give it a fair chance. You did a pretty good job of it. I'll point out however, that you risked further, more serious complication by taking any medication in the attempt to self-doctor. analgesics and barbiturates are amplified by the presence of solvents (booze and sleeping pills) so if you absorbed enough to be effecting you, you could have easily OD'd on the couch.
Thankfully, you've lived to tell the tale, and hopefully those on this board will heed the lesson.
PS: You might well consider going to a fine waterborne lacquer like Target's EmTecH EM6000 which dries fast, works just like lacquer, and won't try to kill you.
David Hay @ Denver
>I'm not necessarily discounting a reaction to the Lacquer. However, perhaps the cramping was related to the way your were holding your hand for a length of time? That is, by devising a less stressful way to hold the item to be finished, you reduced the tension on your finger muscles?
David
Brian in Sandusky, OH
>As you said already, gloves....but you already know that....
You can certainly absorb solvents through your skin with enough exposure.
Your reaction was not typical, however.
Any open cuts, or hangnails? This would speed this reaction through your bloodstream.
My most common reaction to heavy exposure to lacquer is headache or kind of a "hangover" feeling.
There was one time that I cleaned my hands with lacquer thinner, and I had some cuts on my hand from recently removing brush.
Holy smokes, did I feel that. Not muscle pains like you, but a buzz and headache.
buy, and use, some nitrile gloves
Bill Tindall, E.TN
Re: buy, and use, some nitrile gloves
>That had been my first thought, too - but I found some indication online that even nitrile gloves have poor resistance to lacquer and lacquer thinner. Better to hold the material in a way that will eliminate hand contact with the fresh lacquer.
Tony - Memphis
>That was my experience. They lasted longer than latex, but the lacquer ate them right up. I was stripping some door hardware to refinish. I did it outside. Lacquer thinner is some really nasty stuff. I wore a cartirdge mask too, and glasses.
Tony
I Wonder
>if the ladies understand what's really in that nail polish remover they so blithely mop on their fingers.
Re: I Wonder
Howard Acheson
Mostly acetone..
Thanks guys . . .
Pete in Holland, MI
>Yup, gloves would have made a lot of sense, if I had some that the lacquer would not dissolve.
Big wake up call for me. I have been pretty lax with chemicals in the wood shop for years, and this was a wake up call to me that I can really hurt my self. Hopefully my exposure did no long-term damage, but I will take better care of myself in the future.
I wanted to share this so that hopefully others can learn from my decisions.
Pete
