Veritas - Innovation in Tools
Shellac Question
Shellac Question
Shellac Question
cse
>Hi All, I have sprayed shellac (first spraying project) over dye and noticed that some sags and runs formed. I tried to use razor blade to remove the runs but the sags are not too much above surface. I am worried about sanding too much as I have already removed some dye. So the questions are: 1) after building up several coats, can I rub out the runs/sags and 2) can I use alcohol to smooth out the runs/sags
Re: Shellac Question
>Good Morning CSE,
Subsequent applications of shellac will build into previous finish. If the sags are not too bad, you should be able to rub out the surface smooth. You may be able to correct a slight ridge/sag with alcohol applied to a lint free rag and passed lightly and quickly over the area in question, much like a French polish. Too much alcohol exposure will disolve the shellac.
George
various fixes and why it sags easily
Bill Tindall, E.TN
>A very sharp, thin cabinet scraper works well. LV sells a very thin one.
fine sand paper (eg. 360 grit) on a small hardwood block also useful.
If you need to build up some coating thickness before leveling, that is ok too. Just wait for it to get hard.
Shellac is very hard to spray. Lacquer is a solution of a polymer, for example cellulose nitrate. These polymer solutions have a unique property. They have huge increases in solution viscosity when the concentration of the polymer in solution increases just a bit. The lacquer is formulated with solvents that have a variety of boiling points, including one that will flash off quickly. So, when you spray lacquer, some solvent leaves the deposited film quickly and the viscosity of the remaining solution climbs steeply, thereby resisting sags. The remaining solvents leave more slowly thereby promoting leveling. Shellac doesn't have this desirable property because shellac is not a polymer.
Latex paint resists sages by another mechanism. It is formulated with polymers that have the property of getting less viscous when they are sheared(brushed or rolled). Remove the shear and they set up. So, they will spread in response to the shear forces induced by the roller or brush and then remain in place after the roller passes.
Fred Davis
>If your using a spray can of shellac rather then spraying a thicker formula like Zinnsers Sealcost , you will get runs and sags if your not careful because of the thinner solution in the spray can.
It most likely is a lack of practice and not knowing a technique called a tack coat .
Learn to rapidly coat a project the first time with the spray held farther back and swept faster then you normally would.
Let it dry a minute or so until it feels "tacky" to the touch and then you can apply a fuller wet coat without getting the sags and runs. This works as well with Lacquer also.
FredD
