We value your privacy.
>I am sitting on my couch drinking coffee listening to the wind blow in around my windows. I think I have a new honey do to do today before I start on a few woodworking projects for Christmas. It is kind of strange thinking I do not have to be at work until the 4th of Jan 2010(-;
>you can buy kits that have double-sided tape and plastic sheeting that you can apply to the inside of your window trim. You then drag out your heat gun or blow dryer and shrink the plastic sheeting into a pretty clear covering over the window that will stop the incoming air and provides some, probably minimal, insulation value.
I like the Ace hardware version of these kits - the plastic is more flexible on completion than some of the other brands, and seems likely to be stronger.
They're a hassle to clean up in the spring, and bar you from opening the window, so they're not very helpful if your climate is variable over the winter. Until you get a chance to re-weatherstrip your windows or upgrade, though, they'll get you by.
One hint: hold the heat gun farther away from the plastic than you think you should at first, until you get a feeling for the right placement. The plastic goes from shrinking to disappearing in a heartbeat.
Bill, slowly getting shed of having to do this every winter by replacing windows.
>In most houses air infiltration causes greater heat loss than any other single factor, including inadequate insulation. Sealing those windows could make a bigger difference than you might think.
While you're at it check the chimney. If there's free space around it from basement to cap it could be doing an unbelievably efficient job of funneling heat out through your attic vents.
>Tom is right. In many fairly well insulated houses the single largest source of heat loss is Air infiltration. Generally the windows don't leak much unless the wind is blowing. It has to be above about 7 mph to create significant leakage.
The stack effect is another thing. Warm Air rises and tries to escape through the ceiling. If it leaks out, it draws cold air in from down low/through the floor and walls. While you are at it, Seal around your ceiling light fixtures and other penetrations. If you can get a look at your attic insulation, look for dirty spots. It is often dirty because air has been flowing through it and it has filtered out the dirt. Seal the leaks. If you have can lights or recessed lights, they often leak like sieves. Be careful trying to seal them, they rely on the heat loss/air flow to stay cool.
>While replacing a can light is not trivial, there are insulation-contact, mostly-sealed can lights available now. In my opinion, no one should install a can light now that isn't.
>I seal the windows with the shrink plastic every year. I just not had a chance to do it this year. The fireplace I am going to make a wood screen over the next few days to cover it. As for the Attic it has about 20" of insulation in it. I plan on replacing the windows next year as well as the siding at the same time. Thanks Again
>Another area of penetration / heat loss is the air vents. Our local utility paid a crew to go from house to house (by appointment) and apply a sealing strip of what looked to be papermache' around the openings (behind the grills) of all the ceiling vents in our houses plus the sealing up the insides of the A/C-Heating return chase. Before they left they handed us a package of a dozen of C.F.L.s to replace light bulbs throughout the house. My guess is that this is cheaper in the long run than building more power plants.
