finishing drawers?
finishing drawers?
finishing drawers?
Simon St.Laurent - Dryden, NY
>I'm about to build a few drawers - first for a shop project as a test, then similar drawers for some more visible storage projects. They're all overlay false-front drawers.
I've seen folks talk about the dangers of using the wrong oils to finish the inside of a drawer, and suffering a rancid smell forever.
But is there much reason to finish the drawer box itself? I'll be finishing the fronts, of course, but I'm thinking that the box itself, even on the nicer projects, might better be left unfinished.
Re: finishing drawers?
doug f, san clemente, ca
>Simon - even on shop cabinets I give the inside of the drawers a quick coat of a 1-2 lb. cut of shellac. It seems to help with keeping the drawers clean and fresh looking. It also makes me finish sand the inside of the drawers which I would probably not bother with otherwise.
A quick sanding with 220 paper would no doubt suffice, but I'm old and set in my ways.
Have fun with your project.
Doug
another vote for shellac
Dick Coers
Lee Schierer - McKean, PA
>Wood, even when sanded smooth can snag fine fabrics, so I always finish my drawers boxes inside and out with Deft clear lacquer. The odor goes away in a short while and doesn't linger in the clothing or cause any staining. I wouldn't use any finish that says "Oil" in its name.
Lee
A controversial subject
Bill Tindall, E.TN
>There is no doubt in my mind that a lightly finished drawer continues to look and feel better over time. When not finished the wood oxidizes and gets dull and dirty looking. Just look inside old furniture to see what I mean.
I finish drawers by applying a first coat of finish, sand with 220 and apply a second light coat of finish. Then wax the outside if it is a drawer that is hardware- free. I use either a 1 pound cut of shellac or thinned lacquer. These thinned coatings hardly change the initial appearance of the wood, but they make it feel silky smooth and keep it looking good.
You aren't supposed to be able to do this, but I apply the shellac with a foam brush. Work quickly because the gray foam will eventually disintegrate. Or, sometimes I make such a "brush" from white foam which is not affected by alcohol. Why they don't make foam brushes from the solvent resistant white foam to begin with remains a mystery to me.
Clint Searl
Waterborne poly floor finish
Clint Searl
>Varathane or Benjamin Moore. Easy to apply, it's water white, and makes a smooth durable finish. No odor.
Clint
Agree
