Re: There it is...
Fred Davis
>Ahhh so many and so little time .
Jason in a effort to describe that "Mythical client" here is what I meant and I am sure you know also.
Since I was a Journeyman Carpenter long before I was a General Contractor, and advising and hanging extremely expensive Entry doors here are a few things I advised the client to look for and if he didn't opt for the advice I recommended that he look elsewhere for a Contractor.
Most of the Entry doors I have hung were hardwood, especially Oak and if the rails and stiles were not one piece members I advised against the door choice.
For instance there was or still is a door company in Utah that shipped to California door shops ,doors that had two piece laminated stiles and rails which meant that the glue line was directly under two out of every four screws in the hinge leaf.
I insisted on blind stops milled into matching hardwood jambs.
This eliminates the too thin Jambs you see so much now.
Solid brass 4 inch ball bearing square leaf hinges.
Quality entry and deadbolt locks, not subdivision sheetmetal ones
This generally meant Baldwin box mortise locks.
Brass kick plates were a option , but a good idea.
Naturally we advised matching casing.
When you consider that some of the doors from International door company in San Diego and Feather River door in Oroville , Cal, ranged from six to twenty thousand and up depending on how wide the entire entry was and how much artistic glass was incorporated, the price of goodlocks was worth it.
We installed a 16 foot wide double entry in a twelve foot high arched Cherry jamb that was $38,000.00 delivered to BlackHawk,Ca. job site in 1988.
So all told I have done a few doors in forty plus years and I believe that many here would be pleased with McKinney hinges (commonly called Okie hinges in the trade) since they do not require any mortise , only a screwdriver.
Any housewife would have no trouble in hanging a door with these. ;-))
FredD
