Re: Cutting the side arms
GalenV in Iowa
>It doesn't look like you can cut the side member that supports your right roller. Not much room between the upright support and the bolts that look to hold the roller bearing. The bed also extends out to the roller. If you had room to make a cut and the stock was thick enough you could put dowel pins that are all thread with double nuts to allow you to tighten the belt and adjust one side or the other to track. A closer gap could be by using a tee nut set in one side and a jacking nut all with all thread.
A counter top tite joint fastener could also be used as the adjustment across the cut, along with plain guide pins.
If you have not set the final custom belt length maybe you could cut and extend the roller to give more room for adjustment.
Just kicking around ideas.
