Glue up question
>I made some end grained cutting boards. I glued up a bunch of strips and then sanded them flat in the Performax. There was 40 grit paper on the machine so I used it to clean up the surface. That left the surface rough with the parallel grooves characteristic of a drum sander. I changed the paper and sanded it to 120. Then I cross cut them, flipped the strip end to end and turned them ninety degrees to make it end grain and glued them again.
The question is, would it have worked just as well to glue the 40 grit surface? Would there be too much glue left in the joint? (Titebond III). Would the joints have looked open and poorly fitted? Is it time for an experiment?
