Help! Outrageous Fisheye Problem
Steve in East Tennessee
>I just sprayed lacquer on some cabinet fronts I am refinishing. Most turned out just beautiful, but a couple fisheyed like I had never before seen. As I was applying the spray, you could see the lacquer almost bead up like water on a freshly-waxed car. This only happened on a couple of pieces, and they all were prepared the same way.
The original finish is (most likely) poly, and I scuffed all of it with 0000 steel wool. I hand-sanded flat areas with 600-grit wet/dry paper lubricated with mineral spirits. Areas with damage I sanded down to bare wood, and applied a water-based dye, feathering it in to match the original tint. This worked great.
Before applying the lacquer, I wiped everything down with a mineral-spirits soaked rag, and left to dry overnight.
The good ones got a second coat, and rubbed out with rottenstone to a beautiful finish. The oddball ones I've had to re-level, re-tint the areas I sanded through, and generally start all over.
Does this sound like perhaps the fisheyed pieces were somehow contaminated before applying the lacquer? Should I consider adding a washcoat of shellac before re-applying the lacquer? I've never seen lacquer bead up like this did. I knew there was a huge problem the moment the finish hit the wood, so I've got the project idled until I can figure out what went wrong.
I've heard of steel wool having rust-inhibitors or remnants of lubricant from the wool-making process. Could I have gotten some wool that transferred something incompatible with lacquer to the surface of the panels?
