Jewelry Box liner
Jewelry Box liner
Jewelry Box liner
>I've seen the PSA backed felt and velvet sheets in the Woodcraft and Rockler catalogs. I've also seen the "flocking".
I've been asked by a guy to make a box for his girlfriend. I was figuring on coating with a couple of coats of shellac and then putting the lining or flocking.
Which do ya'll prefer. I usually don't make jewelry boxes.
Re: Jewelry Box liner
Bart Goldberg
Bart Goldberg
>Hi, I make alot of gift boxes. Lately, I'm using a brown suede like material I purchased at a local fabric store to cover the box bottom. Because I'm applying the material to the box bottom before the box is constructed, its very easy to cut the material oversized, glue to the plywood bottom, then cut off the excess using a wheel cutter (they sell these at fabrtic stores - looks like a pizza cuter). I use 3M spray adhesive to glue the material to the plywood bottom. I glue the suede material on before I capture the box bottom in a dado or rabbit. After box assembly, I usually cover the suede material with blue painters tape to protect it during finishing. This has worked out quite well so far.
Hope this answers your questions.
Happy Holidays
Bart
Bart Goldberg
Bart Goldberg
>Here is a picture of one box I did this way. I like it better than "flocked" bottoms.
Bart
del schisler
>i have made 100's of jewelry box of all size's I use the gun for my spray Works very well I been doing this for 4 yrs now check out the pages's The best co. to deal with I use the flock from this company
http://www.donjer.com/
http://www.donjer.com/products.htm#Applicators
Clint Searl
Ultrasuede
Clint Searl
Bart Goldberg
Re: Ultrasuede
Bart Goldberg
>Ultrasuede is nice - but its also expensive. The non-leather suede material I purchased was about 20 dollars for a huge piece that I doubt I will ever use up.
Bart
Jerry Samsen
>Here is what I did to line a silver chest (same idea).
I used velvet purchased from a fabric store.
I cut poster board just under the dimensions of the bottom. Then I wrapped the poster board around the top side over the edges and affixed to the bottom of the poster board with carpet tape.
With the poster board wrapped, it fit snug on the bottom. I again used carpet tape to fix the wrapped poster board to the bottom
I did this same process to do the sides.
Came out great.
steve mackay
>I always use felt. Tried flocking a couple times and wound up with a MONSTER mess. And you can't scrape it off inside a drawer. Belive me. I use the thickest felt I can get my hands on so I can "massage" it around and blend the corners. You only need to "hit & fit" the inside and then trim the tops off. I use Elmers wood glue. Just not enough to saturate the felt. Been working for many years so far.
Cork
jesse cloud
Me too.
>I cut cardboard and covered it with velvet. I did not even bother to stick it down with double stick tape. Just made them snug and pressed them into place. They stay in place fine and can be easily replaced if necessary.
Clint Searl
Re: Ultrasuede
Clint Searl
>It only costs a little more to go first class.
Clint
Me three, but I also
Joanne in Pt. Pleasant, PA
>put a piece of thin foam on the poster board and wrapped the fabric (I used ultrasuede or something like it) around it and hot-glued it to the back. I cut it so it fit snugly in the drawer and didn't need glue or tape to stay in. I'll try to dig out pix; they're on the old pc.
Fred Davis
>JL,
what I use to line Jewelry boxes is a cloth specifically made for lining Silverware cases and drawers.
It's Patent name is Pacific cloth ,also know as Silver cloth because the real stuff has thousands of tiny bits of Sliver impregnated in the cloth invisible to the naked eye.
This small amount of Silver collects the gases that oxidize Silver and prevents it from turning black.
It doesn't cost much and the real cloth as opposed to imitations which don't' work , is always Dark Brown, not any other color.
Looks and feels luxurious. Available on the Internet from the West coast by the yard and 52 inches wide.
FredD
Thanks for all the responses.
>Really good stuff to think about. The Silver cloth sounds good - but I think she's a gold sort of person - which doesn't tarnish usually.
Mike Stafford
Mike Stafford
>I used to make a lot of jewelry boxes and my method was similar to Bart's. The main difference is I cut thin cardboard from gift boxes 1/8" smaller in both directions than the bottom of the box or tray that I want to line. Then it is just a matter of cutting my fabric about 1" oversize in both directions and gluing it to the cardboard with spray adhesive. Then I miter the corners of the fabric and fold them under and stick them down with good double sided tape. I also take a couple of strips of the double sided tape and place it on the underside of the fabric covered liner and press it into place on the bottom. Nice and neat operation if you are careful to size the cardboard correctly.
As far as fabric I use ultrasuede, velour, velvet and some other soft fabrics that I find at the fabric store. I have a large inventory of fabric in a variety of colors.
