oil changing tip
oil changing tip
oil changing tip
Bill Tindall, E.TN
>Consistent with my frugal nature I change my own oil. I keep one bottle from the last change to use as a clean, disposable funnel. Cut the bottom off with a pocket knife and insert neck into the filler opening. Remove cap from full bottle and insert into the "funnel". Repeat for remaining bottles and remember to save one capped empty for next time. (I just changed oil)
Re: oil changing tip
An additional tip, for my fellow Idiots.
>Put the plug back in the oil pan before using Bill's excellent tip.
Last time I changed my oil my cell phone rang in the middle of the process. I was walking around talking on the phone. Actually making those noises we make trying to get off the phone, but the other person was having the time of their lives bending my ear. So, to move things along, I poured four quarts of synthetic oil in the top and out the bottom, into the pan that catches it and holds gallons of used oil. Pay attention to the proper order, put the plug back in at the right time.
Dale Lenz
How about....
Dale Lenz
>Pour first qt. in and then cut out bottom of container, less to keep up with and with.
Good idea.
Close but...
Gary Camp, Bend, Oregon
>I dumped 2-1/2 gallons of Anti-Freeze in the jeep with a newly changed timing chain cover gasket. I thought to myself self did I really spill that much coolant? OHnNo, I poked a hole in the radiator. 2-1/2 gallons of Anti-Freeze on the shop floor. Thank goodness for Kitty litter and the NAPA store that acutaly had a radiator on a Sunday
glc
Re: Good idea.
Dale Stansbery
>I found a small orange funnel that has screw on caps on both ends, and I no longer use the quart bottle with the end cut out. I just use the funnel, cap it when I'm done, and it stays clean and doesn't drip where I store it.
Re: Good idea.
Fred Davis
>Well now I know , I bought a Orange thingy like you described and when I remembered to use it several month later, I never found it.
FredD
Jesper, Denmark
Re: Straight Flush
Jesper, Denmark
Re: An additional tip, for my fellow Idiots.
Joe in a Cleveland Suburb
>Been there a couple times Barry. Embarrasing isn't it? :D
Another similar oil change story...
Back in the 80's I raced sports cars in the SCCA. One year I was racing an Alfa Romeo. At the previous race a connecting rod decided to go through the (aluminum) block. So we built a new engine. We bought the best of everything we could to build a better engine.
We were all set to go. Loaded up the car and van and headed to Mid Ohio Sports Car Course. We were all excited about the race and car. We even rented a garage in the paddock (thanks Dad). During practice my oil pressure dropped so I shut it down.
We spent Saturday afternoon and all evening trying to figure out the problem. We worked into the early hours of Sunday morning. We ended up tearing the engine down. We finally discovered a rag in a baffle in the oil pan... never raced that weekend. None of my brothers ever admitted to it. Well, I know it wasn't me!
Ah the good old days...
Jason Roehl in Lafayette, IN
>You were fortunate. A while back, there was a link circulating on the internet to a BMW forum. In that forum was a thread about a young pu...err...kid who owned a BMW. Somehow he lost his oil filler cap, so he decided to stuff the hole with a rag. You see where this is going? That's right--the rag didn't stay put, it got sucked into the valve train and bent it all up. I'm not familiar with BMW engines at all, so I don't know if it was an OHC setup or not, but regardless, there are moving parts underneath the valve covers. And the rag found them. And stopped them at inopportune times.
Jason
Been there, done that, got the shirt
Neal in San Jose
>It doesn't take very long to pump all of the oil out of a Dodge van's motor when you forget to put the new oil filter on. Do I need to explain how I know that?
Guess I have better aim than you guys :-)
GolfSteve in Calgary
>I've never needed a funnel. Turn the bottle the right way (ie. with the hole at the top) and the oil will pour out nice and smooth and predictably. If I'm having a bad day I might spill a bit, but I usually wrap a paper towel around the filler hole that catches any spills.
Reminds me of a sign my Aunt used to have in the bathroom
If you tinkle when you sprinkle,
be a sweetie and wipe the seatie.
Hopefully there's no need for funnels until I'm 75.
Cheers,
Steve
(who started changing his own oil when he found out that VW charges $150 for an oil change)
This is even more fun...
David Sparks
>I left my oil filter off, poured in my oil, and cranked the engine. What a mess that made!
Another Oil-Related Topic
Steve in East Tennessee
>Anybody use motor oil to quench tool steel in the shop? I do, and I (used to) keep it in an aluminum soda can with the top cut off. When not in use, I kept it in an inconspicuous place because "I'll never knock it over if I put it there."
It is amazing how far oil will travel when dropped on a concrete floor at a height of four feet from an open-top container.
Re: Another Oil-Related Topic
>Unlike you, I would have been sure I was going to spill it. The best thing for me would have be to just pour it on the floor and get it over with. Much better than having it fly off the shelf and drench the latest project. Would not even consider storing it in my shop in an open container.
There is a story floating around about someone using a large amount of Liquid Dish Detergent to soak bowl blanks and managing to spill gallons of it. Maybe they will fess up.
