wenge... Anyone work this before?
mike from american sycamore
>I have a one-on-one this week with a lady from Arizona. Her husband had passed away and left her with a nice shop full of tools.(she is nice and pretty too) Oh what a hard job I have! LOL She had helped in the shop but never really was in charge of a project.
We are building a conference table from black wenge. 38" wide and 110" long 3 1/2 x 3 1/2 tapered legs with mortise and tenon construction. 8/4 glue up used for the legs and the apron
we are using 1" for the top with breadboard ends. My hands are sore...full of little splinters that fester up! But the wood works great...saws good, joints and planes, and routes well.
How would you finish this table. I am thinking about sanding and polishing the top to 6000 and us Tried & True. Suggestions?
Thanks,
Mike
Re: wenge... Anyone work this before?
Paul Woolson
>I've used a lot of Wenge. "jumping splinter wood" as I like to call it.
If you really want this table to "pop" I'd highly recommend filling all the pores. What I've found works best is to use West Systems epoxy. Just squeegee it in, let it harden, sand it level, repeat as needed.
As far as a finish goes, I'd probably use a poly of some type over the epoxy.
Good luck with the table.
I like to see the pores.
Stephen Roth
>I also like wenge. (Ditto on the splinters.) I personaly like to see the pores in this open grain wood. For that reason, I use thinned coats of poly to avoid filling the grain too much. I never need to sand beyond 320, because I am not looking for a high sheen or polish.
One problem I find is that there is a sweet spot for finishing the open grain. If you put on too many coats and fill too much of the grain, then the random pores look like mistakes in the finish and you need to go "all the way" and fill them up.
Just my aesthetic for this wood.
jesse cloud
>I hear you about the festering splinters! Try working with Wenge veneer - just when you get it laid up just about right, it kinda explodes!
I've used several different varnishes and poly on Wenge. If that conference table is going to take a lot of wear, you might consider Behlen's Rock Hard varnish. I is very durable and takes a great sheen if that is the look you are going for.
