THE WOODRAT IS BACK!
Rust prevention
Rust prevention
Rust prevention
Al
>Howdy fellas,
I see everywhere that people say to wax the cast iron parts of your equipment to prevent rust, but what kind of wax do you use and where do you get it?
Thanks.
Re: Rust prevention
Re: Rust prevention
del schisler
>do this with this product The best http://www.boeshield.com/ get the T-9 for prevention and smoothness and the Rust free if their is some rust on anything I only use this This rust free will make iron look like new It was mfd By boeing air craft co
Re: Rust prevention
Clint Searl
Re: Rust prevention
Clint Searl
>Butcher's or Johnson paste wax will work as well as anything.
Clint
Re: Rust prevention
Re: Rust prevention
del schisler
>most wood supply places will have those Not just from the co. But you can read about each one
Re: Rust prevention
Re: Rust prevention
Lewis Dodd
>Well, my lathe and cabinet saw are in close proximity and I often use spray silicon on my "ways" and the saw. Sometimes I use Briwax (expensive and have been know to use natural shoe wax. Anything that keeps the humidity or moisture at bay!
Lewis
Re: Rust prevention
Silicon question
Ron Jones
>Has the silicon on either piece of equipment caused problems when finishing (fish eyes)?
Re: Rust prevention
Re: Silicon question
Lewis Dodd
>No, it hasn't. I wipe it down before I use it anyway. I just use the cheap walmart brand.
Lewis
Re: Rust prevention
Re: Rust prevention
jim runchey
>I second the Butcher's wax. Have used it for 30 years or so.
Re: Rust prevention
make you own
Bill Tindall, E.TN
>Dissolve about 1 part Carnuba wax in 1 part turpentine or xylene (turps smells better). You will need to safely heat the solvent some. This stuff lasts well on planers and jointers etc. I put it in an empty wax can along with a fuzzy rag for applying it.
Re: Rust prevention
Re: make you own Thanks Bill, But...
Victor Parisian
>How do You safely heat this stuff? double boiler?
Curious minds need to know.
Victor
Re: Rust prevention
Lewis Dodd
>Warm up excercises first, strike the match and run like hell!
Sorry, couldn't resist, just kidding of course
lewis
Re: Rust prevention
>The way we did it in the lab was heating mantles.
If you don't have a heating mantle, an electric hot plate does work.
I've got an old one that I obtained at a flea market or yard sale. I take it outside and use an old pot with an old candy thermometer. I have my ABC fire extinguisher handy.
You will be heating the solvents above the flash point, so they are generating enough vapor to flash. You don't want spark or flame sources nearby. I do NOT recommend doing this in an enclosed area.
An alternative method which does work somewhat is the double boiler method. You just have to have enough hot water handy. I've contemplated getting a sealed heating point like a glue pot or old frier, but I only mix and heat rarely.
Re: Rust prevention
Silicon is for electronic chips !
Pete in Holland, MI
>Silicon, with out the trialing "e", is pronounced with a short "o". This is the stuff that is grown to make electronic chips.
Silicone, on the other hand, with the trailing e, has the long "o", and is the material you are referencing. Check the spelling on the can.
Pet peeve of mine.
Re: Rust prevention
ways to dissolve the wax
Bill Tindall, E.TN
>1. If you are patient you can just mix the solvent and wax and let it sit a few days. It will make a mush that won't take much heating to dissolve. I don't know the exact temperature but you don't need to be anywhere near boiling to affect dissolution. I don't have any problem picking up the can with bare hands once it is melted so it can't be too hot.
2. I use a hot plate set on low heat, out doors and watch it continuously. As soon as wax is dissolved, or nearly so, I cut off the heat.
3. I will bet that just setting the container in very hot water will work, especially if you do step 1. first.
Making your own is worth the effort because pure Carnuba is very durable and I have never seen any evidence that it will screw up a finish.
Re: Rust prevention
Re: ways to dissolve the wax
Al
>Thanks for all the responses guys. I'm new at owning power tools, and a jointer that I picked up is the first with a cast iron bed, so I'm clueless about how to care for it. ( all my cast iron planes get enough regular use to remain rust free.)
Thanks again, now off to figure out where to buy a hunk of carnuba wax.
Al
Re: Rust prevention
mdclor
>Try Woodcraft if you have one in your area.
