Your favourite Walnut finish
mamc
>Whats your favourite /suggested finish for Walnut?
I am making a TV / component cabinet out of Walnut.
Likely will use Walnut veneer ply for the substrate with solid face frame and top.
I have only worked in Walnut once for a small clock.
It was so long ago I can't even remember what I used to finish it.
Danish oil / couple of coats of poly maybe?
Any suggestions on favourite Walnut finishes appreciated.
Re: Your favourite Walnut finish
jesse cloud
>Walnut takes a wide variety of finishes well. Danish oil or poly will work fine.
I sometimes finish it will a couple of light coats of boiled linseed oil, followed by wax. Many varnishes work well, too. Or even just shellac.
A couple of issues with walnut... It is a somewhat open pored wood and the pores will show with most finishes. If this is not what you want, use a grain filler and a stain before finishing. The other issue is that walnut often has sapwood, which is much lighter than the heartwood. The sapwood will take the finish differently. If this is not what you want, you can selectively apply some dye or stain to the sapwood to even out the colors before the overall finish.
Probably the best advice anyone can give is to save some scrap pieces and try your finish on them before using it on your workpiece.
Hope you will post some pics.
Clint Searl
Oil based poly or lacquer
Clint Searl
>Walnut will take on a rich chocolate red tone with a dilute mahogany stain under the top coat. Don't ruin it with BLO.
Clint
Here's your chance...
>... to do a little experimenting, to get a feel for how various finishes feel and apply. As mentioned above, just about any finish will be fine for walnut.
An indoor entertainment unit is mostly vertical surfaces so the only areas where abrasion resistance is an issue would be the worksurface and the shelves themselves. Everywhere else, linseed oil or Danish oil would be fine. For abrasion resistance, you'd want some sort of lacquer or polyurethane.
If this were intended to imitate the complex color and richness of a period masterpiece, I'd suggest a multi-step regime for laying down ground colors and then enhancing them with trasnparent dyes and glazes.
For new work that doesn't have this need for authenticity, you have a couple choices with walnut: Lacquer is often "water white" or close to it, and forms a very uniform film that you may like or dislike. I'd suggest lacquering a sample or two to see if this appearance and feel are appealing. To warm and enrich the naturally cool brown color of new walnut, you might want to use a reddish-brown dye stain before topcoating. Polyurethane generally has a little more color (tone) to it and tends to give you a warmer look, but it's harder to apply unless you have the skills and equipment to spray it. It is also more difficult to repair than most other finishes.
Danish oil tends to darken and dull walnut as it penetrates, and maybe this is the effect you are looking for. To protect wear surfaces, you might want to follow up with a varnish of some sort. I'm a Waterlox fan, but at $45 per quart or whatever they're charging nowadays, I'm opting for different alternatives nowadays.
On the latest walnut piece I built, I brushed on a coat of SealCoat dewaxed shellac full strength, then sanded lightly with 220-grit and wiped on a couple dilute (cut 20% with naphtha) coats of Helmsman clear gloss spar varnish, which is relatively inexpensive compared to Waterlox and handles quite nicely when diluted. It goes on very thin so it dries dust free sooner, with fewer drips, sags and brush marks; but it takes probably twice as many coats to get an even build and sheen. Be sure to use gloss and not satin. If you want a more satiny surface, rub out the final coat with 0000 steel wool or synthetic abrasive pad and wipe with a very dilute varnish solution, then buff off the excess.
My Favorite Walnut Finish
>For furniture and flatwork:
1. Use a dye stain sparingly to blend any sapwood. No stain otherwise.
2. Seal and pop the grain with 2 coats of fresh dewaxed dark garnet shellac. 1st coat at .75lb cut, next at 1.5lb cut.
3. Fill pores with Crystal-lac filler sanded off with the grain.
4. Topcoat with either oil poly or waterborn acrylic lacquer or hp poly.
For turnings:
Waterlox high gloss
Here's One *LINK*
>Without the shellac - just dye, oil poly, and grain filler
Walnut
Walnut turning color?
DouginDenver
>One issue not raised in any of the responses that I have been meaning to ask about is the way walnut changes color with time. Woods like cherry and mahogany get better and better looking as they get darker and richer - unless in very extreme direct sunlight for long periods. Walnut is one of my favorite woods except that even in indirect light it tends to lighten with time into a rather odd-looking greenish gold color that I personally find quite unattractive. Does anyone know of the best things to use to preserve something close to the look unstained or undyed wood, but keep it from turning color?
Clint Searl
Re: Oil based poly or lacquer
Clint Searl
>Poly over dilute mahogany stain
Clint Searl
'nother view
Clint Searl
Re: Walnut turning color?
>Doug,
You're up against the Great Changer (the Sun), and the best you'll do is hold off the inevitable for a while. The advantage of some oil finishes (tung especially) is that the are natural UV blockers. Thus look over what you plan on using and choose compounds rated highly for UV exposure. The walnut in my foyer (at link) has bee largely unchanged for 10 years although it gets direct sun at some point during the year. The combination of pore filler and oil poly has done will. Can't say, however, what would have happened in a picture window on the south side of a house in Tucson
paul in AZ------WebKitFormBoundary+isMX5X2paiDYC5e
>Mark, I can answer that.
I built a dining room table 20+ years ago and it has been in that very brightly lit south facing picture window in Tempe [Phoenix] for many years. It has gone from the original rich, dark walnut color to a uniform medium brown sort of like milk chocolate. No discolorations at all. It still looks fine to me.
I can't remember if I used BLO under the poly finish or not. I suspect I did because I tend to do that with most domestic woods.
Um
>Hey Paul,
With all the Spam Bots putting alphabet soup on the Board these days, maybe you can consider changing your login "handle"?
Bill Tindall, E.TN
>I always stain walnut with some oil stain that is, or looks like, burnt umber. Stain keeps the walnut looking good for decades. Otherwise walnut can bleach to what I consider an unattractive shade. For a formal piece I will fill the pores, typically just the top. As far as the top coat, it depends on the piece and what it will be used for. If it needs to be durable I will varnish it. If its reproduction I will shellac it. Or I might lacquer it.
Re: Um
>I'd love to but that gobblydegook seems to be something that the server assigns to Mac users. Not something I put there. I've tried deleting it and things i post disappear into ether.
I've also written Ellis but there doesn't seem to be any solution.
Ah Yes, The MAC Issue.
>I think he's working on it.
Safari issue
>This is a known issue with Opera and Safari browsers which will go away once I have the new version of the 'boards up and tested. Meanwhile, we try to ignore it. Firefox is the antidote.
Re: Um
Dan Donaldson
>I don't believe that the problem is the Mac itself, but is with Safari. Some Mac users use Firefox and have no problems.
BarbS
Mac on Firefox works fine here.
BarbS
Another happy Mac/Firefox user
Bruce, a MN Galoot
Thanks lots of great ideas and formulas!
mamc
