What grits of sandpaper/Drum sander?
>I am looking into buying bulk rolls of sandpaper for my 16/32 drum sander. What grits would you buy? Thinking of 36, 50, 80, 120. Could go 36, 60, 100 and I have some 150. What grits do you get the most out of?
Re: What grits of sandpaper/Drum sander?
Rick L
Re: Grtis
Rick L
>80,100,120 will probably be your most used grits. Get some others to try for yourself. Don't skip grits as coarse scratches are hardest to sand out. YOU WILL need to random orbit the panels. Drum sanders leave a kind of ripple similar to a planer.
If you have space in your shop consider a small stroke sander. Much superior to a drum sander for finish sanding and can go right to finishing from the machine.
Have used widebelts, drum sanders, stroke sanders, and other sanders in commercial wood and metal shops for 35 years on pine to stainless steel.
Robert R. Clough - Thorncraft
>For my 16/32 I use 120 primarily. I have one (1) 36 grit which I used once several years ago - never again. I use 60 and 80 very seldom, 100 and 150 sometimes. Since I have no planer my sander is used to dimension lumber - within limits obviously. As I am strictly a hobbyist I enjoy setting a machine up and have no objection to taking a long time to do a job. Generally I prefer to go at 1/64" at a time although I occasionally go to 1/32" or even 3/64". 120 is just coarse enough to do a decent job.
Oh yes, I do use hand planes as well.
Re: Grtis
Lewis Dodd
>UH, color me dumb, but what is a stroke sander?
Lewis
Rick L
Re: Not dumb...young and *LINK*
Rick L
>you probably never worked in a furniture factory.
Stroke sanders were very common years ago. Just because you don't hear much about them doesn't mean it's outdated technology. I'd take a stroke sander over a drum sander any day. In one shop we had 4 stroke sanders and one widebelt. They kind of over lap some of the duties of a widebelt.
1. SS are cheap compared to a widebelt. You can sometimes find them for scrap metal prices. Belts are cheap and belt changes are fast.
2. You can do wider pieces than a widebelt but length can be limiting on a stroke sander
3. Storke sander is a finishing sander not a thickness sander. Drum sander and widebelts without platens leave drum ripples which must be sanded out by hand or random orbit.
4. A bit of a learning curve with a stroke sander but certainly doable.
There's more...
Stroke sander
Carol Reed - home in Strawberry
>I have had a Performax for a bunch of years. I only use 120. I have a planer, so I only use the Performax to get machine marks out. I had a 50 or 60 grit belt and it was so stiff I couldn't keep it on the machine. The machine is not a wood hog. It is a finesser.
I run the wood before final cutting to size. I also run it to get to exact thickness when dadoing. The router bit has a fixed diameter. I can adjust the wood thickness to fit.
A good bandsaw blade for resawing makes a 120 grit belt more than sufficient for final smoothing.
My version of KISS!
