Edging plywood?
Edging plywood?
Edging plywood?
Simon St.Laurent - Dryden, NY
>I'm going to be building a set of pieces that are basically cabinets but will get used upstairs for storage. The changing table I mentioned earlier is the fanciest of them, but I'd like all of them to look good by cabinet standards if not by fine furniture standards.
I'll be using Baltic Birch for the bodies, and drawer slides inside. The main thing I'm left concerned about is the edges of the plywood. Though I do like the look of Baltic Birch edges on shop cabinets, it's not really what I want upstairs.
I've used the veneer before and didn't like it much at all. I think it's probably best kept behind cabinet door edges, and a lot of these edges will be visible. I'd rather go with solid wood for that, and have birch sitting in my shop anyway, ready for use.
There are lots of articles and bits of books that talk about edging. Some just glue the edge of the wood to the edge of the plywood and call it a day, while others use tongue-and-groove joints, splines, or biscuits. Lee Valley has a dedicated plywood edging router bit set that seems well thought out, but maybe that's overkill?
Any thoughts on how best to apply a solid wooden edge to plywood?
Thanks!
Re: Edging plywood?
Re: Edging plywood?
Virgil Johnson
>From where I'm sitting I can see a total of 24 white oak plywood drawer fronts and cabinet doors that I edged with solid oak. I glued it (no joinery) and called it a day/evening/morning. No failures after 3+ years of daily use.
Re: Edging plywood?
Louie Lovas
Re: Edging plywood?
Louie Lovas
>I've done quite a lot of plywood edging, both for shop projects and furniture. I use the same general technique for both - biscuits. While you don't really need them for strength, they sure make alignment a lot easier. I usually thickness the edging about .015 (15 thousands) more than the plywood. By using biscuits I can ensure the surfaces are reasonably aligned with minimal cleanup (sanding, scraping, planing). This is especially true if you need both sides clean. It also helps, if your narrow hardwood edging starts to misshape (take on that banana shape) soon after you rip it - which often happens.
I also have used this when edging laminate when you have little (if any) ability to clean-up the edge.
Of course there are many ways to skin this cat, but I find myself using biscuits (#0 and #10 only) more often than not.
Re: Edging plywood?
Re: Edging plywood?
Fred Davis
>How about Frame and Panel construction with the door panel and end panels being plywood.
Ued the same approach for the drawer fronts.
Mitered frame with ply panel for the fronts.
FredD
Re: Edging plywood?
Re: Edging plywood? *LINK*
Joanne in Pt. Pleasant, PA
>I use cherry. Nice contrast. Here's what I posted to Ed's question about this below:
http://www.woodcentral.com/cgi-bin/messages3.pl?read=402743
Re: Edging plywood?
frame-and-panel someday...
>but for right now, that's still too fancy for where I'm at. I'm moving back into woodworking slowly, trying to get simple things to work before getting excited about better ways to work.
Re: Edging plywood?
Re: Edging plywood?
Chrispy
>I have a rental property with 35 yer old cabinets that were not much when new. I decided to update with new cabinet doors but wanted to keep the cost down and above all to reduce the effort involved. Therefore I made the doors as simple overlay using just oak veneer plywood. The trick was to tilt the sawblade to about 13 degrees, thus when the doors are fitted you cannot see the edges, therefore no need to apply edging. The finish was one coat of hand wiped tung oil/Helasman spar varnish. They look great!
Chrispy
Re: Edging plywood?
Re: I like the look -
>Just glue. Some people use biscuits to line up the 2 pieces. I don't have one of those tools. I have used splines in the past (same idea). Mostly I just glue and clamp. Sometimes I have to trim if the pieces don't line up perfectly. I made a little jig for that for my router.
Re: Edging plywood?
Re: I like the look of Everything Joanne Does-
>As well as her method of attachment. Glue is great, and I've never had a failure. My edging tends to be 1/2" or more thick, and NORMally I use pins "TO HOLD WHILE THE GLUE DRIES". :<)
George
Re: Edging plywood?
Awww. That's why you're my favorite!
Re: Edging plywood?
Re: Edging plywood?
David Hay @ Denver
>Whenever I've added edging to plywood, I've just used glue and clamps. If the edging is thinner (say 1/4" or so), I don't even use clamps, I'll hold it in place with painters tape.
Some are probably good enough to get the edging on without any trimming. I typically have to make my edging about 1/16" oversize and trim flush with a router or hand plane.
David
