200+ woodworking book reviews
close-up of finish on wood *LINK*
Simon St.Laurent - Dryden, NY
>Violin-makers are probably most interested, but I suspect everyone's heard of Stradivarius violins and the constant quest to figure out what he did differently.
"a detailed analysis of the varnish on five instruments made by Antonio Stradivari reveals that he coated the wood with a rather humdrum mix of oil and resin."
The picture at top is especially cool, though.
What Exalts Stradivarius? Not Varnish, Study Says
Re: close-up of finish on wood *LINK*
oil depth
>I probably should have mentioned this earlier, but there's something interesting going on in the picture. You can see how the oil gets into the wood, or doesn't.
It looks like the oil gets into the top layer of wood cells, and maybe around to the bottom of them. A lot of those cells have broken walls, which would make it easier. The varnish layer seems to rest on top of that.
I've always wondered how deep oil could go into wood. Looking at this, my guess is still "not far".
interesting article, thanks
Bill Tindall, E.TN
Re: Wooden Boat Builders Don't Agree
Cecil Nickerson
>I shamelesly lifted this qoute from a Finnish boat builder about his experiences with linseed oil/pine tar mix. Of course a boat is no violin.
"The whole idea of impregnating a boat is in getting the oil as deep in the wood as possible. It is said that no surface treatment will soak any deeper then a few cells in the wood. Sadly, that's very true, but linseed oil impregnation isn't a surface treatment. Think of a leaky diesel engine in your boat: diesel oil seeps through the planking in an alarming speed. Just as well thin linseed oil can be soaked through the planking, if necessary�
"�We impregnated a 13-metre traditional Finnish lapstrake gaffer a few years ago. Records show that the boat got 50-60 coats of oil all over. It's a quick job doing it once, but this took a while. Later we drilled a drain hole on the bottom and found out that the lowest board, about 30 mm (1 1/4") thick was impregnated with oil and tar all the way through."
For what it's worth, Cecil
Clint Searl
What he really used
Clint Searl
>He actually invented that revered witches brew of BLO, poly, and mineral spirits. Now you know the rest of the story.
Clint
Wow!
>I'm especially impressed as that's linseed oil, which is what seems to provoke a lot of the scoffing.
I don't _think_ pine tar would make it soak in easier. And the comparison to diesel fuel definitely brings the point home.
Thanks!
Re: What he really used
Glenn Madsen
>Where can I get me some of that 400 yr old poly? ;-)
