Small Cherry Case
Small Cherry Case
Alan Young
Small Cherry Case
Alan Young
>Hi Friends,
I am finishing up work on a small Cherry Storage Case.
The design is a variation from a piece my client found in a
Blue and Yellow Northern European Furnishings Chain. :^).
The original piece was 6 feet high and had three open shelves. My client wanted some changes
to the design and after several iterations we settled on this shorter version. The revised version is 56" high.
I was pre-occupied with building and didn't start taking progress shots till it was this far along.
Next I made the door which is comprised of a cherry veneered panel and mortise and tenon rails and styles for the frame.
The frame is glued together and the panel is veneered in cherry on both sides.
Each piece has rabbet cut around it's mating perimeter.
When placed togther the front has a small recess between the panel and the frame.
The back side has a flush fit.
This cabinet will be located in a place where space is at a premium.
Even a door knob may pose a problem by catching a person's garment when they walk past.
The solution is a finger hole in the door or drawer with an accompanying brass ring set flush to the surface.
The door ring is 1" in diameter and the drawer ring is larger-at 1.75" The drawer ring is made first.
I began by drilling a 1/4inch hole in square out piece of 1/2 thick brass stock.
Then I mounded the stock on a 1" piece of tapped steel and chucked it in the lathe where I turned it round.
I move to a drilling operation. First I centered the hole in the vise, then using a 1 1/8" slugger cutter
I drilled out one side of the ring.
I was using a tapping block to support the brass and didn't want to mar the surface by cutting all the way through.
So I flipped the piece and finished the cut from the other side.
Then it was back to the lathe to bore out the center hole a bit larger.
Now for the door ring. This piece is less complicated. Some 1" brass stock is bored out on the lathe
then parted of at a 1/2" thickness.
Here they are ready to go.
My client wanted a little spice to the piece and picked out a banding for the drawer.
I did not make the banding but obtained this
Tulipwood/Brazilian Boxwood (17mm-11/16in.) banding from Inlay Product World Inc.
Once again I got caught up in the process of building and didn't stop to take progress shots.
The the banding is inlaid into the solid cherry drawer front and the brass rings are set inside the door and drawer,
Almost ready for the finish.
Here it is after a coat of Danish Oil. I'll follow with a coat "Sealcoat" then probably a couple coats of Satin poly.....
Thanks for Looking...Alan
Re: Small Cherry Case
>Good Afternoon Allan,
That is a very pleasing piece, and I like the revised shorter design. I especially enjoyed the metalwork fabrication. Its somethng I know almost nothing about, but looks good--like women. :<)
George
Clint Searl
Handsome
Clint Searl
Like the drawer.
>I think that the door needs something more though. I mean, I like the general size and all - but I want to see something more.
How to say it - the drawer has a focal point with the insert in the center and the inlay all around. IMO, the door need something similar to unify the piece.
I love the style.
Beautiful
Tom Rex in TX
Alan Young
George-You know just enough
Alan Young
>about women that is :^)
Alan Young
uumm.....
Alan Young
>I am not in disagreement...there is some banding left over..maybe it's not too late.... We'll see what Mrs. Client thinks.
ALan
