Question on toybox lid hardware?
>Thinking of making a toybox for my Niece.
The devices that hold the lid up for safety, are they the hinges too or do you use hinges and supports? Do you buy different ones of different weights or are they adjustable?
Where do I get them?
Re: Question on toybox lid hardware?
PS, Whats a good size for a toybox?
BilWil
>Rockler has some hinges that don't require any supports. I have used them for tow boxes and like them.
How many toys? :)
>I always make a toy box or cedar chest so that it is a comfortable height to sit upon. For a child, that is on the order of 16" high (cedar chest or blanket chests are higher). Width is proportional or similar to the height. Length is proportional to the width. So, call it 16 x 16 x either 32" or 40".
Lee Schierer - McKean, PA
>I've used the Rockler lid supports and they do a good job and seem to hold up for years of use. You also need good hinges in addition to the lid supports. Piano hinges are pretty easy to install and hold up well. You will need to follow the sizing directions and size the lid supports for the weight of your door.
Lee
Lewis Dodd
>Just finished one for my Grandson.
I put a piano hinge and the lid supports and all works well. Had to call tech support at rockler for mounting the lid supports, kinda critical as they do not swing entirely open, only about 85 degrees. You gotta buy one for each side, right and left. I used item numbers 26187 and 26211 at $5.59 each. They work great. They now have some that serve both as a support and a hinge. With the potential for abuse, I chose the piano hinge and the supports. My box was 18" high, 18" deep and 48" long with two hidden or "secret" compartments and a sliding tray for stuff that would eventually get "lost" on the bottom.
Good Luck
Lewis
