We value your privacy.
>I used my lock miter bit for the first time yesterday. I followed all the instructions in the MLCS manual and video and took small cuts to sneak up on the full miter. But I gotta tell you I was terrified! That is one scary operation. It felt like the bit wanted to grab the workpiece even with the smallest of cuts. And running the pieces through in the upright position had me shaking with fear of a kickback.
I wasn't expecting excellent results my first time and I know the joints will get better the more I practice but if I have to be afraid of losing a finger each time I'm giving up while I'm ahead. So do you more experienced woodworkers have any advice, tips, tricks, or warnings that will help me become better at this operation? All ten of my fingers thank you.
>Two pieces of advice, make a sled and throw it away.
Actually, they are both right. If that cutter scares you that badly, either make a sled or throw it away. This hobby should be fun and productive, not terribly scary.
My experience with router tables and shapers is that sleds and other hold down devices are tremendously worthwhile. I have made several that completely changed the operations from iffy and scary to smooth and repeatable. You may need two for this, one for the piece that lays on the table and one for the upright one.
Sometimes the jigs take more work than the pieces themselves.
>That's a good idea Grant. I was using a handheld scrap of wood to push the pieces through so I think a jig with a handle will be an improvemant. Designing something for the upright pieces will be a challenge though. I'll see what I can come up with.
>Safety is so important, you don't ever want to be doing anything in the shop that makes you fearful. That says you don't know what you're doing and naturally you are worried that something will go wrong. Further, practicing the wrong approach isn't going to make the approach less dangerous. Hence, it's good to ask, and here is a fine place to ask. Here are a few observations that might help...
Any large router cutter will remove a lot of wood in a hurry if you let it. That's not always bad, but unless you have a good way to control the workpiece, it can be. Make sure you observe the proper RPM range for the diameter of the cutter you're using. Your lock miter is probably best run at between 10,000 and 13,000 rpm. If you don't have a variable speed router, now might be a good time to get one.
You didn't mention the size of the pieces you're mitering, but unless they're very narrow, you shouldn't have any fears. By all means, make some sturdy featherboards and use them, for both the horizontal and vertical setups. A good featherboard does two important things: it holds the workpiece firmly against the fence or table (or both) so your joint will be perfect, and it acts as a barrier for stray fingers. If the piece is narrow, use a pushblock and a featherboard. I like the pushblock design that looks like a boot. You can use it to direct pressure downward and forward at the same time, and it keeps your hand well above the cutter.
>Here is a relatively simple version you could whip up in a half hour.
As for the vertical pass you must make, you could run the same sled on edge along a tall fence. That said, however, it would be best to create a vertical sled that is captive to the router fence to limit movement and thereby get a better, safer cut. Depending on the shape of your router fence, you might be able to add a few pieces of wood to the below jig to make it captive on your fence.
You can find other examples of sleds by doing a google search something like:
"Router sled .pdf"
or
"router coping sled .pdf"
using the .pdf brings to the top of the list all pdf documents, which have a good chance of being an actual plan.
>Any time you're working with only part of a bit exposed in front of the fence, the first thing you want to do is minimize the gap in the fence. You DO NOT want the beginning or end of the stock to get BEHIND the fence.
And when you're using a large router bit - 2 to 3" in diameter - you want to use the lowest speed a variable speed routers will spin at - typically 10,000 rpms or so - NOT 28,000 to 30,000 rpms that are typical of fixed speed routers.
Rather than featherboards to hold the stock down on the table, or upright against the fence, I'd go with two fairly easy jigs to make
(see attached).
You want
- the part of the part that's supposed to be
flat on the router table top ACTUALLY flat on
the router table top - and keep it there.
- the part that's supposed to be against the
fence STAY against the fence
- a part to be routed vertical to actually be
square to the router table top
That's true whether you're working with a Lock Miter Bit, a Raised Panel Bit or a Cope or Stick BIT.
The Lock Miter is tricky to set up properly because, ideally, you want a knive edge on the mitered corners parts. It's really easy to overshoot the "depth of cut" - and shorten down the dimension of a part. Also easy to undershoot the setting - and end up with "flats" one the edges of the mitered parts - which will stand out like a sore thumb when the parts are assembled.
When working with this bit, it's really nice to have a precision positionable fence - with replaceable zero clearance inserts in the fence. The JoinTech Cabinet Maker System is such a set up I'm familiar with since I own and use one. You can dial the fence back and forth in .001" "click tactile feedback" increments.
With such a fence system you can sneak up on the "depth of cut" and once you get it, literally "dial back" so you can do progressive cuts, the last being only .002 to .003 inches for a nice finish on the cut surface.
>Yes...they are scary. I have one and never use anymore. Aside from safety I found myself spending way too much time setting up to use the bit (safely) and the results were too inconsistent. I suggest you select another joinery method.
>Thanks for the warning about the router speed. Mine is fixed at 25000 rpm. Yikes! Hmmm. Might have to put this procedure on hold for a while. (I'm still gonna make a jig though. I love jigs.)
>Guess I'll have to use another method till I can slow down the rpm. I need to practice my dovetails anyway. But I'm not giving up. I see this as a challenge and I will prevail. (someday)
>Hey Tom, looks like you and me are in the same boat. I tried my lock miter bit for the first time this week also. Tried to use it without any instructions, with real crappy results. Finally remembered an article in a recent issue of one of the WW mags(either AW or Wood) &
dug it out. Had to make some trial cuts to arrive at the final result, but at least now I am set. Just remember to retain a sample of the good result to use as a set-up gauge for the next time.
Feather boards and push blocks got used to protect the digits.
