"Picture rail"?
"Picture rail"?
"Picture rail"?
>The folks over at the Playhouse want me to mount something on a cinderblock wall so that they can hang picture/posters of old shows. They are all framed.
My first thought was to just put up a couple of ledger strips so that somebody could just put a screw, nail or picture hanger on the ledger and mount the picture.
My second thought was to put up something like a long "plate rack" so that they could just lean the picture against the wall. I was figuring on something that was maybe 2 to 2 1/2" deep with a 1/2" lip. I'd attach it to a 1 1/2" or 2" ledger strip. I'd put up maybe 2 of these.
Any other ideas? Which do ya'll think would be better?
Re: "Picture rail"?
Re: "Picture rail"?
Lewis Dodd
>I would only suggest that the pictures be mounted where they are not "easily" removable, else many will remove them to look at them or whatever
lewis
Re: "Picture rail"?
French cleat
>It's much more secure and the posters will lie flat against the wall.
Re: "Picture rail"?
The posters/pictures are all in frames.
>They are all about 8 1/2 x 11.
Re: "Picture rail"?
Jason Roehl in Lafayette, IN
Traditional picture rail...
>...at least as I understand it, is similar to the French cleat diagram Ellis posted, but mounted high on the wall (i.e. 9' up on a 10' wall). Then, clips and thin-gauge picture wire (cable) are used to hang the picture to whatever the desired height.
Jason
Re: "Picture rail"?
Lots of older houses here have them
>The clips are commonly available locally. The molding is usually mounted about 1/2" down form the ceiling. Could be anywhere.
Re: "Picture rail"?
Re: Traditional picture rail...
John E in SC
>I mounted a traditional picture rail moulding down in our basement "playroom" to make it easy to display the kids artwork, and change it regularly. I think I bought the picture rail locally, but had to order the hooks off the 'net. I just use a thin gauge wire. Makes it easy to change arrangments.
Re: "Picture rail"?
All you have to do is...
>...make up short sections of cleat that you can either screw or double-stick-tape to the back of the pictures and/or frames.
