THE WOODRAT IS BACK!
So I made this cutting board
Bob Entwisle in NJ
>Walnut with Cherry stripes, 7-1/2 x 18-3/4" x 3/4"
Claphams Beeswax Salad Bowl Finish.
Re: So I made this cutting board
Jesper, Denmark
Jesper, Denmark
>Very nice.
Can you show a pic. of the routing set-up for the juice groove? I assume you made a jg? How did you locate the board in the jig?
That's beautiful, Bob
David Barnett - SW FL Gulf Coast
>Both the wood and the design. Could kick me into another walnut phase.
Fred Davis
>Really to nice to cut on Bob ;-))
FredD
Re: So I made this cutting board - template
Bob Entwisle in NJ
>Jesper,
Basicly I just made a template out of 1/4" ply and double stick taped it to the board blank. I recently made some guitar parts and had fitted a template base to my trim router. I found I like the fine control that the small trim router gaves me, so I used the same base and router with a cut down template bushing and a 1/2" core box bit. here is a picture of the template:
Re: So I made this cutting board - router
Bob Entwisle in NJ
>Here is a picture of the router base, template bushing, and bit.
Re: That's beautiful, Bob
Bob Entwisle in NJ
>Thanks David.
If this kicks you into a walnut phase then my destruction of this piece of walnut is almost justified!
Re: So I made this cutting board - thanks Fred
Bob Entwisle in NJ
>It's just another slice off my to-do list.
Re: - locating template
Bob Entwisle in NJ
>Jesper,
On locating the template, I just placed the template onto the blank, and then measured a bit to locate it, I then put locating pencil marks on the template and blank. Then I pulled the template off, applied the double stick tape, and layed the template back down, lining up the pencil marks (and hoping I didn't go too far off them). I think the picture I posted has the 'tape side' of the template up (so I didn't get tape residue on the finished board), which is why you don't see the locating marks.
Don't take a vernier to it, but it seems to look ok.
Jesper, Denmark
Jesper, Denmark
>Great, thanks. It is an inspiration.
Chuck in ND
>Nice job Bob.
