OT - screw size?
OT - screw size?
OT - screw size?
>I am helping a friend install a bathroom light fixture.
In the midst of her moving and everything, she lost the screw which holds a finial on one of the fixtures. 6-32 is too loose and 8-32 is too large. It does not appear to be 4-0.7 (too large). Could it be a 6-40? The plate which attaches to the junction box and hold the fixture to the wall has similar sized screws (with nuts). I was not able to get the nuts on the end of an 8-32 screw (at least very far) and the nuts were definitely loose on a 6-32 screw.
So - what would be a "standard" sized screw for holding on a finial that would also secure a fixture to a plate?
TIA
Re: OT - screw size?
>6-32 and 8-32 are common; you'll occasionally find 8-36.
Does the nut begin to turn on to the 8-32 thread and then stop after a turn or so? If so, it's probably not a size mismatch but a pitch mismatch. In that case, find a fine thread (8-36) screw, and see if that fits.
I've never seen a 6-40 thread in a light fixture or, for that matter, anywhere in the wild; though I'm sure they're out there someplace.
Re: OT - screw size? METRIC !
Dave (PacNW)
>Okay, I'll look for a fine thread 8-36. It did go on a little on that.
Could be
>but I've purchased several imported light fixtures, and have yet to find one that had metric screws.
Drill and tap it for the size you have.
gil jones...GA
del schisler
>i guess you only HAD 1 screw ? Take the nut to HD or lowes and see what fits They have a screw board that has all different thread size's and metric also
