routing thing strips
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA
>If I needed to have some kind of shape on the edge a thin strip of wood -- e.g. 1/4 inch, I wouldn't route it; I would rout the shape first on a wider board and then cut the strip. But suppose you already have the strips -- say you got a gift of some fine , thin strips. What's a safe way to shape the edges?
Re: routing thing strips
>The strips are 1/4 x 5/16 x 18 inches.
Ed Mulligan, Cape Cod MA
>Tell us more: What are the strips made of? Why is it important to work on them rather than make new strips the way you suggested? What are you using them for?
Bart Goldberg
Bart Goldberg
>Without knowing more, I would suggest either hot gluing, or double sided taping the strips to a larger block of wood to router safely.
Bart
Like Bart said, except
Thad------WebKitFormBoundary2MUKv+qM98ILr0mA
>if these strips are as fine as you say, and you want to/must use them, I'd probably go a bit overkill and skip the hot-melt glue or tape, and just wood glue them to a carrier board. then rip the glue joint after shaping.
~ Thad
I did just this operation on 80 1/4" X 3/4" strips
Bruce, a MN Galoot
>when I made my canoe. Each of the strip's edges were routed with a cove and bead. This can easily be done safely.
All you need to do is make fingerboards that hold the strips down on the router table and against the fence, both fore and aft of the bit. Maybe that's a little overkill, but your own fingers won't even get close to the bit.
Bruce
Re: I did just this operation on 80 1/4" X 3/4" st
>How do you push the strips past the bit with finger boards holding against the fence and against the table? I have the same problem with table saw ripping of a thin strip when I use a finger board that holds against the fence and down against the table. It's o.k. if the strips are long enough and you only need a portion of the strip, but if you have to route the entire length of the strip, there would seem to be difficulty getting past the finger boards.
Pull them through
>The nice thing about fingerboards is that your own fingers don't have to get anywhere near the cutter.
>Use the next strip to push the existing strip through, and, as Ellis suggests, pull the last one through after you've got enough length to grab onto.
Re: If you decide not to use the carriage board
North of the Border
>method but want to try the direct routing method as some suggested (with the use of featherboards, pulling and pushing, etc.), I offer these additional suggestions:
a) take very light cuts by setting the fence incrementally,
b) Use bit that has sharp edges
c) if your stock can chip off or tear put easily and if you're routing a round profile, consider rounding off the stock edges (assuming they're square) slightly with a jig on a belt sander.
One caution: routing a 3/4" stock is not the same as routing a 1/4" stock. In other words, what works for 3/4" stock doesn't necessarily work for yours. So try out whatever method you want to try on a scarp 1/4" piece first.
>It's fancy mahogany, already in strips, so no larger stock to work from. The project looks much like a raised panel frame , and what I'm doing is decorating it by putting a thin frame within the larger frame.
Fred Davis
>I used to this on hundreds of feet of wood shelf edging with a small Delta Shaper.
The same way should work for a router table./
Get a block of wood about two inches sq. in cross section and a foot long.
Cut a slot lengthwise that is a snug fit over the strips.
Drill a recess into the middle of the block for clearance of the router bit and chips.
Clamp this jig to the router fence and push your strip into the slot slowly , when it starts out the out feed end ,grab it and pull the strip the rest of the way.
This way if your setup is done correctly it will eliminate a tendency for the small strip to shatter and if it does , there is no way your fingers will be damaged.
Beyond that , the ripping off of a moulded piece from a wider board is still the easiest method.
FredD
>I like Fred's idea, IF your strips are accurately all the same size. If not, there will be some that are loose or some so tight they won't pass through. Finger boards would ignore slight variations in size, but would not hold the strips as securely if they tried to chatter. I would make sure all the strips are identical and then use Fred's technique. And I would add Bill's suggestion of feeding one after another until they are all done. I think it would reduce tear out at the beginning and ends of the strips.
>Thanks! I like your idea best! Some of the others are great , too; but this one seems safest.
>Thanks for the follow-up. Looks like you have received some good advice below. I especially like Fred's method. Good luck!
