Re: Is this the Take Away? *LINK*
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Barry, Epoxies don't have volatiles or moisture that need to evaporate to cure, so they keep better than most adhesives. I started with West, but hated the pumps when I needed more than a small amount. Those pumps can get slow, and, take in air, causing a little bubble blast which will throw off the ratio of whatever you have already pumped. That is very frustrating.
I switched to System 3, which I liked better, but then found FCI which is much cheaper by a lot than either of the above. You can buy the standard 1 - 1, which is very forgiving in its ratio.
I keep little 2 oz. solo cups to measure small amounts, and all sizes up to 16 oz. I find it a lot easier to just sit two cups side by side on the edge of the bench, then pour an equal amount in each, then mix them together.
Most projects, I don't bother pouring it into a roller tray, I just pour a small stream ahead of the roller while I am rolling out veneers and substrates etc.
I keep colloidal silica on hand to thicken it to whatever viscosity I feel that I need. I hardly ever use it straight. This is a very light powder. A 2 oz cup of it mixed into a 12 oz mix in a 16 oz cup will make it about as thick as latex paint. 4 oz will make it about like catsup, and 6 oz about like mayo, and 8 about like peanut-butter. You could use it that thick if you wanted to use a 3/8" tenon in a 1/2" mortise, and it would probably be as strong as any well fitted 3/8" T in a 3/8" M. Not that I am encouraging that.
Here is a link to my source. You can buy one resin, and use it with a huge selection of activators to get whatever properties you need, like storing strong acids or solvents to certain structural properties. The price is better, because they supply large industry, and don't advertise a lot like the first mentioned epoxies that most of us start out with.
You can but a two gallon kit of this for about what you would pay for a quart of the others.
As with any brand that you choose, I would suggest that you get their manual, and glean whatever you can from their information. That will keep you out of trouble, and open new paths of adventure.
http://www.fgci.com/
