Performax 22-44 Sander problem...
doug f, san clemente, ca
>I've had this drum sander for about 4 years and it's performed admirably all that time.
BUT, in the last week or so when I've been running it for 4-5 minutes it starts to emit a howling that sounds an awful lot like a bad bearing.
Does anyone have this sander and have you had occasion to change the bearings? Is this a difficult fix or should I be contacting the seller to make the repair.
I couldn't find this particular issue addressed in past messages and I'm hoping someone may have the answer.
Thanks for your help.
Doug
Re: Performax 22-44 Sander problem...
Grant in Iowa
>Is the howling associated with the main motor/drum, or with the feed belt?
Guessing you are right, and that it is a bearing issue.
FWIW,
Grant in Iowa
>Grant - It's definitely in the drum. When I turn off the feed belt and simply run the drum, it occurs after about 5 minutes time. Doesn't seem to be the motor, but the drum itself. I just can't tell which end is making the noise.
Doug
Re: Performax 22-44 Sander problem... *LINK*
Grant in Iowa
>Doug,
You can be reasonably sure that the drum bearings are to blame. One way to be certain is to run the machine until the noise begins, then remove the coupling between the motor and drum and run it again AND/ OR spin the drum by hand with the coupling removed. That may not be easy to do in practice, however, and you may simply elect to replace the bearings.
Jet part # (Jet bought Performax and will sell parts) 50-3089 Drum Bearing NTN 6205 2 required.
The link below contains the manual for your sander which includes the parts diagram and list. You will need to go to page 30 for the diagram and 31 for the parts list
If you find the bearings are prohibitively expensive from Jet, head off to a local bearing supplier (yellow pages under "bearings").
Regards,
Grant in Iowa
Jet 22-44 manual
Be Careful
>You must make surethat the replacement bearings are double sealed to keep abrasives out. Bearing number should be followed by the "ZZ" or "LL" designation. You can google NTN's site, put in the bearing number, and verify which ones are double sealed; there may be 6 with the same number but different suffixes. Rely on the accuracy of a company "parts list" at your own peril.
Re: Be Careful
jcousins
>i just had to replace the drum because the bearing race came loose and "wow'd" the drum spindle - so i had to remove the bearings to install them on the new drum. i used a puller to remove the bearings - they came off very easy and they just tapped right back on.
jerry
