New toy and some questions
Randy Johnson
>I bit the bullet yesterday and bought the last air compressor I will ever need. It exceeds any possible use I could ever come up with.
Until a few weeks ago my compressor (the vertical 30 gallon Dewalt that is sold everywhere) was used for two things; a brad driver, and blowing dust off of things. However, I�m now starting to move toward using more air tools and the DeWalt simply doesn�t have what it takes.
I pretty much know how to handle 95% of the plumbing but there are a few questions.
The compressor is a five HP two stage Ingersol Rand with an 80 gallon tank. The outlet and valve supplied with the compressor is half inch. I was planning on making the main run from the compressor � inch. (30X30 building) Will the current � restriction need to be replaced with � or will it be sufficient to �pack� the � at the start of the run?
My biggest question involves filters, regulators, and filter/lubricators.
In line with the question I have already asked, does the pipe on both sides of the filter/regulator/lubricator at the compressor need to be sized for the largest pipe or can it be reduced to half inch?
I know I will have to have regulators at all of the drops, but will I need to have a filter at each one or will the filter at the compressor take care of it?
For what it is worth, I think my biggest problem of all is how I�m going to get the compressor from the bed of my pickup to where it will sit in the shop. It is one of the disadvantages of getting older you seldom think about. Most of my friends are not in good enough condition to wrestle top heavy 400 pound compressors around. I will probably be borrowing my company's installation truck with the lift gate.
