Large Diameter Template Guide for PC 690?
Tony Sade (Charleston, WV)
>I need to rout a grease groove in a cutting board using a PC 690 set up with a plunge base, probably using a core box or fluting bit, and need to find a template guide big enough to handle a 3?"4 inch bit. Does such a thing exist, and if so, where?
Thanks,
Tony
Re: Large Diameter Template Guide for PC 690?
>I don't think I've ever really seen one quite that large. I know the largest ID that I have is maybe 5/8".
Jim Dillon
>Tony,
Like JL, I have never seen a bit that big for a handheld router (and I probably would be scared to use it, if it was available 8-)). If I were doing this, I would use my 1-inch (3/4-inch ?)cove bit, along with the router edge guide to very carefully cut a grease groove in the cutting board. Then, if you need a slightly wider groove, move the edge guide and cut again - keeping the depth the same. Actually, that size cove bit will cut a nice groove in one pass. What you are trying to do would be a lot easier if you have the plunge router accessory for the PC690. In fact, I just did what you are attempting only my groove was only 3-inches long. Worked just fine. Hope this helps.
Jim
Jim Dillon
>Tony,
Naturally, right after I posted my first message, I thought of how I would REALLY do this. But you need the plunge base (to be safer), a router guide bearing, and a template cut to the cutting board shape, minus the appropriate offset. This would work regardless of the cutting board's shape. Stick the template to the middle of the cutting board with double-sided tape, then rout away. You might have to cut off a bit of the PC guide bearing with a hacksaw as they seem to be longer than necessary - at least mine was. And I think the widest bit you can use is 3/4-inch or so, but I could be mistaken.
Jim
How I would do this.....
>I would put the cutting board on a piece of plywood or table and build a frame around it of scraps. The top surface of the scraps should be the same height as the board. Put some more scraps on top of the frame as a fence along each side. These fences should be offset from the groove according to the distance from the center of the bit to the edge of the base. Be sure the board and frame around it are snug or very secure in relation to each other (Nothing wiggles in relation to the other). Run the router around the inside of the fence to create the groove. Practice or find out which way the router tends to "run". Go in the direction that tends to push the router toward the fence.
This is easier to do than to describe. If your router has one of those bases with the flat side on it, keep the round side toward the fence (important at the corners). The fences can be short at the corners so the dust will blow out of them, just less than the radius of the base. Be sure the dust does not build up ahead of the router and create bumps on the fence. If the groove is not wide enough you can tape a spacer inside the fence and run it again. Do this in small increments to avoid ridges in the bottom of the groove.
You can do this with a fence on the router or with a single fence moved to each side of the work piece, but then you have to predict the corners VERY carefully. By doing it with a picture frame , the corners take care of themselves. This way you don't need the guide bushing at all.
I use the base of the router for a guide often. I know the question of accuracy and whether the base is concentric to the bit comes up, but on a cutting board, its irrelevant.
Thanks, all.
>Jim:
What you've described is exactly what I was planning to do, provided I can find a template guide with a big enough ID to handle a 3/4" bit. I have an edge guide, but the few time I've used it to go around a 90 degree corner, I've found it difficult to keep the guide fast to the stock.
Cheers,
Tony
Re: Large Diameter Template Guide for PC 690? *LINK*
Andy Lincoln,in Dearborn MI
>Tony,
Here is a link to one retailer selling a template guide bushing set that has a 1" x 7/8" guide bushing.I have seen large diameter ones and I am going to keep looking.
Andy
http://www.eagleamerica.com/product/400-1419/router_accessories
Re: Thanks, all.
Jim Dillon
>Tony,
Yes, I understand what you are saying and your concern popped into my mind as I was walking the dogs after I posted my first suggestion, hence my second suggestion. Some cutting boards have handles, so the template option has advantages.
I just checked on the ID of my two sets of router bearings (I'm having a real senior moment here as I can't recall the exact name for these gizmos 8-( ). The maximum ID for the PC set is 5/8 inch. The maximum ID for the brass Woodcraft set (purchased maybe 5 years ago)is 7/8 inch.
If you need to slightly widen the groove, you could easily mark beforehand, the 1/4 inch or so offset on the template, then cut and trim to size after you've routed the first groove. But I actually think a goove cut with a 3/4 inch cove (or round-end bit) should be enough for a grease channel. Sounds like a neat project!
Jim
Bill Hylton
>Tony,
PC has a 1 1/4" O.D. template guide; part number 42021. (Presuming that B&D didn't deep six it.)
But you can make a template guide almost any size you want.
1. Cut a piece of 1/4" MDF to serve as a router baseplate and mount it on the router with the baseplate screws.
2. Use a V-groover in the router to mark the bit axis on this MDF subbase (just hand tighten the bit in the collet, bottom the bit against the plate, and spin it by hand).
3. Remove the plate from the router. Securely glue a scrap of MDF (1/2" or 1/4" thick) to the outside of the plate. This is going to become the guide collar.
4. Drill a hole through the plate and collar-to-be at the spot marked by the V-groover. This will be a trammel pivot hole, right on the bit axis.
5. With a router and trammel, rout a circular groove of a diameter matching the O.D. of the collar you want. Cut only as deep as the thickness of the collar material. Trim away any waste outside the collar.
6. Remount the plate on the router, install a bit, and plunge it through your baseplate/template guide.
It has worked for me!
Bill
Another thought.....
>Why not buy a bearing and collar that fit the shaft of the bit. Install it on top of the bit and use it as a guide. You can buy bearings in many sizes for this. I have a set that fits on 1/4" shafts.
Bill White
>Not gonna catch me spinnin' something that big on my 690. TOO FAST=SHRAPNEL.
