We value your privacy.
>I am in need of buying a new miter gauge.I bought a new powermatic table saw, contractor series, and the miter gauge that comes from the factory will make a good door stop but nothing else. I have looked at incra v120 and 1000hd models along with kreg miter gauges. Anybody bought one lately that they can talk about. Thanks for your time.
>Lynn, I am interested in your post, not because I have anything to offer, but I find myself in the same boat. I would be interested in hearing pros and cons of any of the miter gauges offered. I have been leaning toward the Osbourne EB-3, but would welcome hearing the good and bad on any and all!
>I have had one of the Incra miter gauges for several years, I think it is the 1000, not the cheapest one but the one above it. I like it a LOT. I bought the Osborn a few years ago but I seldom use it. The Incra is easier by far to quickly set up for all the angles between 90 and 45.
>I bought one of the Kreg miter gauges for use with my unisaw when they first came out, I believe. Bought two lengths of bars, the drop stops, and a couple of other things. I use them seldom.
Not because they are bad, though. They are quite good. I just use sleds a lot more, ones I made. These get used where a sled doesn't work, and the gauge still does.
There is a ground for something else, maybe a wider sled, that's required once in a while. What that is, I haven't figured out yet, nor do I need it often.
>The school has several "ADVANCED" miter gauges. We have the Osborne, Incra, Rockler, and the JDS. The JDS is my favorite and my go to one. I like the beef and the stops are dead on. I do not use the hold down much except when I use it on the shaper or router table. The sled recommendation is excellent advise. I believe a good sled would out preform most applications other that miter work. I have the large unit from that router place in Iowa? and a Dubby? Both work very well.
>Have been using an Incra for several years now and wouldn't be able to live without it. I have a Miter 5000, with the sled, which is really deluxe, but a bit awkward to put on and off the saw if I need to rip. I think their current 1000 SE is probably the sweet spot. Anyway, I find the repeatability based on those positive stops and incremental settings to have transformed my woodworking. I love being able to change an angle, then come back and get exactly the same angle again, not "close enough", but rather exactly the same, at any angle, not just a few presets. Combined with the same ability on the stop settings on the extended fence, I can make pieces way more reliably and repeatably. If you haven't used an incra jig or another of their units based on the same principles, you really should give it a try. I did try an Osbourne at one point, and it is good, but I returned it, bought the Incra, and haven't looked back. I also have their table saw fence and love it, too.
>cutting mitres tells me that there's a lot more to getting good mitred cuts than the mitre gauge. You need a lot things right, such as mitre slot being parallel to the blade; minimal vibration (table and blade); good blade; and good stock preparation (is it true?), in addition to a good mitre gauge. Y9u may spend a lot money on a top mitre gauge but still can't the kind of mitre cut you expect. I only work the mitre gauge that came with my T/S and a large drafting triangle to set my mitre angle. I also find my Dewalt compound mitre saw makes very accurate mitre angle cuts. A $120(?) mitre gauge would be way down on my shopping list, well below a quality tablesaw blade that I might buy. Make sure you've got the other factors taken care of before you go out and buy a top-rated mitre gauge or you could be disappointed.
