Have a question? Ask Woody!
shed roof question
shed roof question
Donna Parrillo
shed roof question
Donna Parrillo
>Hi,
I made a trash shed recently and am having trouble with one section of the lift-up roof, which has distorted. I used thick exterior-grade plywood, which I then sealed with a Cabot waterproofer. I also sealed the edges of the plywood with silicone to keep water out. I plan on removing this section of roof and will try to fix/flatten it. Does anyone have any good ideas on how to go about this? I will try to attach a photo. Thanks, Donna Parrillo
Re: shed roof question
Donna Parrillo
Donna Parrillo
>Just trying to post a clearer photo. -Donna
John Veerkamp, Western Mo
>Donna,
I'm afraid you're not going to be happy with exterior grade ply, no matter how you sealed it, some moisture will penetrate the edges eventually. Marine grade ply would work better. If cost is a consideration and you need to stay with the exterior, seal the edges with several coats of paint. Then paint with a light color, the entire roof. The sun on the wet ply, wicked up from the bottom edge is likely the cause of your warping.
Good luck,
John
Dave Tenney
>Plywood left exposed like that is always going to be a problem.
If it were me, I'd look at some sections of steel roofing over a 2 by frame. It would probably weigh about the same (Maybe lighter) and would last for ever.
mdclor
>You could try using one or more battens to pull it into alignment.....
>Sort of on the order of what mdclor suggested. Have a frame or battens on the edges of your plywood.
I don't know if they do metal roofs in your area of the country. I would think that metal roofing with an appropriate edging or frame would look attractive. It comes in a variety of colors and isn't that expensive. Be careful when you cut it though.
I've got some green that was left over from my house roof. I couldn't bear to throw it away. It is now sitting under the front porch.
Gary Evans--Tallassee TN
>+1 on the idea of a metal roof. Around here you can get the metal panels precut to the size you need. I would expect the weight to come out somewhere close to the weight of 3/4" plywood, especially as you are going to need to build a frame for the plywood to keep it flat.
Gary
Donna Parrillo
Donna Parrillo
>Thank you everyone for offering some very good ideas to solve this.
-Donna
