gluing fabric to wood
eliot d
>Would you say that hot melt glue is a good way to attach fabric to wood? Is there a better way?
Re: gluing fabric to wood
Joseph Mulherin, Sr
>Think about trying contact cement liberally for good contact and good absorbtion into the fabric....
Ed Mulligan, Cape Cod MA
>If it's for a large surface area, and if the fabric is suitable, consider wallpaper paste.
Norm-Knoxville
>I have used a spray adhesive from 3M and Loctite for a variety of fabrics to wood with good results.
Joseph Mulherin, Sr
>Question: just what are you making? If it is a chair, then use uphostelery tacks along with the glue. Please explain what item you are making....
John McGaw
>I've only really done it once in woodworking but I found that 3M Hi-Strength 90 is great for attaching heavy upholstery fabric to solid backing in a set of folding screens.
eliot d
>It's a bit unusual: actually a pastel box. It consists of two boxes, each 12 x 18 x 1 1/2 inches. These two boxes are hinged so it can lay open and then close up to something like a briefcase. Each 12 x 18 section has a removable lid with three layers of soft fabric attached so that when the lid is in place over the pastel sticks and the box closed, the pastel sticks don't all fall down to the bottom of the box and probably break. So I want to glue a 12 x 18 inch rectangle of soft fabric to these 12 x 18 inch wooden lids.( If you're not familiar with pastel sticks, these are something like soft chalk sticks that you "paint" art stuff with.)
steve mackay
>I mount all my work to bases of red oak and felt the bottoms. I also cut a square out of the middle of the felt and "insert" my card. I've tried a lot of methods and, years ago, settled on yellow glue for the entire operation. Even though I've had things return, years latter, for repair from moving or child damage that felt and card are still "one with the wood".
Joseph Mulherin, Sr
>OK, Elliot, I understand now what the project is and I agree with John McCaw's statement on the 3m hi strength 90 adhesive....cost is nice too. You are making a floding tablet-like briefcase for the pastel pencils...right? and they will be cushioned from falling below when the case id=s closed. Use the 3M product...
Fred Davis
>I agree , PVA glues are formulated for gluing projects like yours.
One thing I discovered early on was to make sure the glue film was thin to avoid soaking through to the top of the cloth and making it hard to the touch.
Rubber cement will also do the trick, but you need to work fast for large areas.
FredD
eliot d
>Thanks all; I guess I'll go with the 3M hi strength 90 product.
LOL ! . . .
steve mackay
>AND it took my awgile to figure out the best way to spread it thin was to use a finger as a squeegee. Made some really good messes 'till then.
Caveat
David Barnett - SW FL Gulf Coast
>Anything that can irritate your skin or eyes can adversely alter the binders and pigments in pastels. I'd opt for anything archival, something a bookbinder might use: hot hide glue, rice paste or wallpaper paste.
Sobo is safe, too.
>Sobo, a flexible, sticky PVA formulated for crafters, is also okay. You can find this in most craft and fabric stores.
Re: Caveat
eliot d
>Well, my original post asked if hot melt glue was a good choice. You are the only one who said anything about hot glue. I was convinced by several of the posts that 3M would be best. Now, you've got me wondering. But shouldn't all be well after the glue dries? Or will it continue to out-gas something harmful to the pastels. A really good set of pastels is extremely expensive, so, indeed, I don't want to ruin them.
Re: Caveat
>David recommended hot hide glue, not hot melt glue.
Joseph Mulherin, Sr
>Elliot, another product came to mind....try asking around for the adhesive they use for installing roof lining materials in autos.
Re: Caveat
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA
>You convinced me! I went out and bought some Sobo.
Probably prudent
>You didn't say whether these are commercial or handmade pastels, but even if you make your own (which I did) they're anything but cheap. I don't know if anything might react to the sodium orthophenyl phenate used to preserve the gum tragacanth binder or whether delicate pigments might be compromised, but I'd rather not find out the hard way. Sounds like a nice project, btw.
Sobo may not be quite as archival as my preferred Talas glues but I've taught binding entire books using it with no deleterious effects, and some of those books are decades older than I care to admit.
Re: Probably prudent
>I have a variety of pastel sticks, e.g. Nupastel, Rembrant, Sennelier. How do you make your own? A reference would be good enough.
Handmade pastels *LINK*
>Here's how to make those buttery smooth pastels. There are other online sources, too. Just Google "making pastels". Look up "handmade pastels" to see soft pastels others make (and often sell).
Although you'll probably order your pigments from Kremer or Sennelier or whomever, you can find pigments from other sources (often cheaper), especially the earths; umbers, siennas, ochres. I also grind lapis lazuli 'scrap' for ultramarine blue. Much cheaper.
You should probably get a small mortar and pestle or a glass muller for pigment grinding (or make your own - I did).
I took art lessons as a child using Rembrandt and Grumbacher, but in college learned the value of handmades for more painterly effects. It's been awhile since I made any but I always enjoyed the process and the results.
How to make pastels by hand
Oops! *LINK*
>Meant 'Sinopia', not Sennelier.
Sinopia
