QSWO weight/board foot
mdclor
>Hi to all,
I want to make a wood run to get a load of qswo. My truck is rated at 1400 pounds net of the driver. Dried white oak weighs about 47 pounds/cubic foot. I have seen board foot weights ranging from 3.8 to 4.2 pounds/bf. Therefore, I think I would be safe getting 300 bf, but I want to maximize the 670 mile round trip.
As a one time event, would it be safe to get as much as 400 bf? Would it make any difference if the wood was 4/4 or 8/4? If I overload the truck, should I increase the tire pressure?
I would prefer to not rent a flatbed truck since I don't have a friend that owns one. I might be able to rent a trailer reasonably, but haven't looked into that. Any other thoughts or considerations?
TIA,
Merle
Re: QSWO weight/board foot
Jennifer@Indy.USA
>Merel,
We just had 400 bdft of QSWO and cherry delivered and it came in a Dodge Dakota. It was way full, but it got here. I think 400 bdft for any full size standard PU is doable.
Enjoy the haul!
Jen
mdclor
>Jennifer,
I have a full sized Toyota Tundra, so this is very reassuring.
Thank you!
>I don't have a Tundra, but as I recall from my niece who has one - it will haul about 1500 lbs or tow about 6500 lbs.
The one advantage to towing is you can haul more and longer boards. I think that would be something to consider. I recently rented a truck to haul 1700 or so board feet. The cost of rental for the flat bed was $80 plus $0.10/mile. Of course I had to fill the truck back up with diesel. That worked for me.
>As a long time over loader of pickups, I would not hesitate to haul that load in that truck. (I once went to the query and got 7500 lbs of gravel in my half ton Chevy. It was only about five miles, but I felt so bad I nearly killed myself in the race to unload it. That was a mistake. I did not want nearly that much gravel.)
Another consideration is the length of the lumber. If you are getting 8 or 10' stuff, you will be fine. 16' stuff might be another question. (Long load might put too much weight behind the rear axle, making the front really light and the steering unreliable. Shorter stuff balances most of the weight over the rear axle and some of it on the front.) Carry some ratchet straps. I might put a couple under and around the load even if it were not too long, just to keep it from shifting.
I would look at the tires and if they are squashed down, I would "air them up a bit". Forty PSI or more to get the sidewalls back up. THEN, don't forget to let the excess air out when you unload the truck.
more to it than just weight
Bill Tindall, E.TN
>I routinely hauled 500 bdft of hardwood lumber in a half ton Econoline van. However, more weight was distributed on the front wheels than would be the case with a pick up truck. I once hauled 600 bdft of cherry 700 miles back from New York but it was only 8' long. What will be important is how much of the load hangs over the back wheels, which will in turn depends on the bed length and the lumber length.
In fact, as a practical matter the load will be limited by the capacity of the back wheels to take the load. A friend hauled at least 500 bdft or 12-16' mahogany on a 3/4 ton pick up but it had exceptional sturdy tires on the back. It swayed a lot but the tires handled it just fine.
I also routinely pulled a trailer with a ton of rock or fire wood with this van, or now days with a Ford Explorer. I could easily pull more if the trailer would handle it. So another possibility is to borrow or rent a 10 or 12' trailer with a 3500 pound axle(s).
Jesse Cloud
>At 12% moisture content, white oak will weight about 4 pounds per board foot. In New Mexico, the moisture content may be much less.
mdclor
>Thanks to everyone. I remembered a lot from JL's similar questions but thought it would be good to double check myself. I think I will explore the trailer option to increase my capacity. That way if anyone locally wants anything I will be able to get it for them.
Merle
Here's a calculator, and...
Grant in Iowa
>Here's a handy online calculator thanks to woodweb.
Pay attention to the length of the lumber. You don't want the center of gravity of the load to be behind the rear wheels, and ideally as far forward of them as possible. For a full sized truck with an 8' bed, that means ten foot lumber is about all you could handle at full truck capacity.
If you have an extended or crew cab truck, the bed is likely shorter, and so the safe length is shorter.
The best answer is a trailer. If such lumber is so scarce in your area, it may pay to "invest" in more than you need and sell off what you don't need in order to pay for the trailer rental. That is of course your call, however.
As you can see from the calculator, a change in moisture content doesn't matter as much as most people think:
500 BFt at 12% is 1934 lbs
500 BFt at 7% is 1907 lbs
Not that it means much, but I routinely load 2000+ lbs in my 1/2 ton chevy pickup, but then I am not going 300 miles that way.
All considered, I'd try to find a trailer... much nicer ride, too. Your average car trailer will haul 5000+ lbs, which translates to much more lumber, not even counting what you could comfortably load in the pickup in addition...
If you ask me, it is time to move to where the wood is!
FWIW,
Grant in Iowa
'Attsa lottsa turning ahead
A. Kapocius
Oh, and if you need to tarp it...
Grant in Iowa
>Here's how I tarp a load of lumber:
-Use a tarp that is long enough to be longer than the length of your lumber plus twice the height of the pile you will be loading.
-just before the lumber is loaded, lay the tarp over the cab of the truck and pull the rear edge of the tarp down the back of the cab and fold and runs rearward on the floor of the bed a foot or so.
-Load your lumber such that it lays on the foot of the tarp that is in the front of the bed
-now stretch out the secured tarp over the lumber and strap across the front and rear of the bed to the tie down points. If your lumber extends much beyond the rear of the truck, add a third strap around the lumber and the tarp at the rear of the stack.
I use this method whenever I haul lumber if the weather is threatening rain. Having the tarp beneath the front of the lumber ensures it won't fly off while driving, and provides a better rain seal.
But maybe you don't need a tarp in your area...thought I'd share anyway.
Regards,
Grant in Iowa
Jesse Cloud
>Where are you going? I don't need anything right now, but would be curious to know what's out there.
I think Grant may be right 'maybe its time to move where the wood is?'
mdclor
>We moved to the Albuquerque area from upstate NY where the wood is plentiful and we have no desire to move back to that part of the world-the sunshine in ABQ is just toooooo nice!
I mostly make mission style furniture so the qswo is obligatory although I could also use cherry, but most of the other furniture is already in oak. Cherry is not all that common in NM either.
Anyhow, I will explore local trailer options. I found what I believe to be quite reasonable pricing at Frank Paxton in Denver. They have select and better grade 4/4 and 5/4 readily available. It is random widths (4"+wider), random lengths (6'+longer) in the rough. 500 to 1000 bf will last me quite a while so I should only need to make this run every couple years.
I really appreciate all the suggestions.
Merle
