Delta bandsaw table slippage
Don in STL
>I have an almost six-year old Delta 26-208 bandsaw that has only been used five or six times. Recently I decided it was time to set it up properly and get some use out of it. In the process I bent over to pick up something off the floor and leaned on the table to support myself. The table pivoted down, as though it was loose. When I attempted to push it back level it became obvious that it was no longer connected to the base of the saw. The front and back trunnions had crumbled into little pieces.
I contacted Delta, who kindly sent me replacements. They said that the trunnions are made of zinc and the castings are thin, being only .050 inch thick.
I have remounted the table, but I find that just like with the original trunnions the table must be turned down really tight to keep it from slipping. I suspect that this is why the original trunnions failed.
Has anyone else experienced a similar problem and if so, did you find a way to resolve the table slippage problem without having to over tighten the adjustment?
Thanks for your help.
