RIDGID Oscillating Edge/belt Spindle Sander *LINK*
Tom Rex in TX
>What is your opinion of this sander?
Ridgid Sander
Re: RIDGID Oscillating Edge/belt Spindle Sander *LINK*
mdclor
>Tom,
Although I couldn't find it using the Search function, I saw a string within the past month. IIRC, the users were generally happy with it. Perhaps someone will be able to critique it for you. Seems like the Colonel contributed to that string and he wasn't at all abrasive about it.
Sorry, not much for you to go on.
Merle
I had one ...
Mike Farinella
>If you can get past the plethora of plastic, it should be OK for the hobbyist. Personally, I couldn't wait to get rid of it.
Simon St.Laurent - Dryden, NY
>It does well in reviews, and I've wished for years that I'd bought that instead of my Grizzly 1014Z. I've only used one briefly, but the results were great - oscillating really does make a difference, it seems!
(I think Fine Woodworking listed it recently in its "tools to buy in a recession," but maybe it was someplace else?)
del schisler
>I have had two They have been very good I would buy another one if needed The only thing to do is the locking nut or bolt that hold's the belt sander on or the spindle sleve on losen it when done If you don't it will get so dam tight you will not be able to change from belt to spindle That's what happen to the first one A pipe wrinch couldn't get it loose So i took it back and got another one free Other than that i see nothing wrong with unit I use mine a lot for spindle right now But the belt works ok But you have to watch it on the ends It will not sand flat for the 6" i belive it is it put's like a dent in the end or snipe That is where the flat metel piece that holds the belt ends for the price not bad
Scott Crumpton
>I have one of the original gray ones and use it extensively and hard. It's a good machine, but does have its problems. If you intend to use it to produce straight edges, get a bigger machine. It works really well for sanding the edges of "shapes".
You will probably experience belt tracking problems. Good belts (Klingspor) help a lot. It will also track better as the entire belt heats up to the same temperature. Using a platform on the table so that you're sanding in the middle of the belt will also help with the tracking.
If used for long times, the motor will overheat. This can be remedied by improving the dust collection. Screw a jointer dust collection adapter to the back of the sander so that it covers the dust collection port and the vent on the back. It should extend above the table by about 2-3 inches. The hose connection should be at the bottom. Cut away the plastic slots in the vent to improve airflow over the motor even more. With this mod, my unit no longer overheats and I can sand for hours at a time. Dust collection is better too.
I'd buy another in a heartbeat if this one died.
---Scott.
Re: I had one ...
Carol Reed - home in Strawberry
>What did you you replace it with? Or did you? I have a big spindle sander. I am more interested in the belt sander.
Gerry In North Surrey
>I like mine too. I also have one of the original grey ones and it has performed very well. Dust collection is not as good as it could be so I'm going to try Scott's solution.
Gerry
I grit my teeth, Merle
Yonak
>I had one, but I overlooked the part about it being a hobbyist tool. I burned up the motor. Unfortunately, I either didn't know or forgot about it having a lifetime warranty, so I took it to the dump instead of back to the store.
My biggest complaint was that the belt attachment, at the end away from the spindle, wasn't very firm and it shook, so fine sanding wasn't an option.
Kelly Anderson
>Mine is excellent. It works perfectly, never had a problem.
Re: I grit my teeth, Merle
mdclor
>Sorry, I was thinking of Colonel Sanders.... ;-)
Never did ...
Mike Farinella
>I currently use a drum/spindle sander mounted in a drill press.
I Like Mine
Ken Krawford
>I've had one for 4-5 years and really like it. I just finished a pair of Adirondack chairs and used it a bunch. I like having the option of spindle/belt sanding on the same machine. I picked mine up for $150 when HD had them on sale.
Jesse Cloud
>I've had one for a few years. Its ok, but not great. Lots of plastic, the two part table is not flat and just about impossible to keep square to the spindle. But my main use is for fairing curves in 1/4 inch mdf. Its probably as good as any of the low cost oscillating sanders and the jump to the next level of quality is very steep.
He Chickened Out
Bill White
>I have been well served by mine. Just gotta get good belts so the splices don't beat ya to death.
Bill
