Edge Gluing thing stock Questions
>A couple of years ago I picked up some scraps and edge glued them and made a pizza peal (peel?) out of them. A piece of cherry about twenty inches long in the middle and a piece for soft maple on each side. Sort of a giant spatula. I planed it on both sides so that the lead end is very thin (less than and eighth) and it is about 5/8" at the handle.
We use it Putting pizzas into and taking them out of the oven. Works very well.
The problem is that the glue joints are failing near the thin end. I can't remember what I used but it was probably Titebond. It doesn't get hot or at least stay hot long, the pizza is slide off onto a cutting board pretty quickly.
We enjoy it, so I want to make the new improved version. So, what was my mistake? Making it too thin? Gluing it up at all? Should I have made the taper Sort of a double taper? Thicker and then sharper at the leading edge?
Re: Edge Gluing thing stock Questions
>Good Evening Barry,
I've frequently glued edges of thin stock, and never had a failure. I've always used white or yellow carpenters' glue. My guess is that your pizza peel lost its moisture and the wood shrank. Or, there was insufficient glue and clamping pressure at that portion of the joint. I suspect the latter, or a combination of the two. Pepperoni and mushrooms, green bell peppers, onion work well. During Lent, I substitute clams for the pepperoni.
George
Bill Earl
>I've made a few peels and have a couple commercially made ones as well. We use them regularly and they all have developed splits over time. I suspect that it is more due to the moisture of repeated washings rather than the heat of the oven.
Not all have split at the glue joints. But all of them have splits.
use a cookie sheet
Bill Tindall, E.TN
>Not nearly as authentic but I use a cookie sheet and place the dough on a piece of parchment paper.
But to answer your question:
1. You have been washing the peal. Don't wash it.
2. the wood was too wet when you glued it up.
American Woodworker Article
A. Kapocius
>Pizza peel project was written up in American Woodworker magazine some months back (this year). The 3/4" stock was glued up, much like yours with accent strips. The never to be divulged secret is to make up a jig with tapered thickness support strips and a thickness planer. Mebbe someone can come up with a specific reference.
Al Kapocius
