Moss growing on roof
Lynn Reedy Soddy Daisy Tn.
>I need to know if anybody knows of a product that will kill moss growing on my roof in a shaded area. Cannot damage or discolor roofing.
Re: Moss growing on roof
Fred Davis
>I had that problem on a house with Shakes in California and I used Copper Green which is a brand of Copper Salts, also a product called Penta which is Pentachloraphenol will do it.
Keep both products off of you , don't inhale the Penta .
FredD
Re: Moss growing on roof *LINK*
Lee Schierer - McKean, PA
>When we lived in South Carolina, many homes had problems with moss or fungus growing on their roofs leaving ugly black stains. As I recall the cure was to install zinc strips near the peak of the roof so they were exposed to the rain. The rain water would leach off small quantities of the zinc which would run down the roof and kill the moss/fungus without changing the color of the roofing.
I cannot say for sure that the strips worked since our house didn't have them and wasn't old enough when we left to have developed fungus.
Lee
Zinc strips
George Koch
>Lynn,I cured the problem by spraying the shingles with a bleach/clorine solution with a garden sprayer. George
>Read both of the responses above.
If the moss you are asking about is really moss (a green plant with chlorophyll and roots, the penta will work and you could even use Roundup.
If it the black or brown roof stain, (most probably a fungi) then the zinc strips will arrest it.
The black stains can be washed off or removed with a roof washing solution. Google roof stains. You can make your own washing solution. Most of them contain soap or a surfactant and are very slippery. Be extremely careful not to slide off the roof and crush the shrubs. Also, probably not a good idea to power wash the roof if it is asphalt shingle unless you know what you are doing and use very low pressure. (Sort of an Oxymoron, a low pressure power washer. Perhaps a hose)
You did not say what kind of roofing you have. Power Washing can also damage shakes.
Ronald
>Bleach is the cheapest and it will work!! I work partime for a power washing company and we use bleach to kill the moss.
Fred Davis
>You can kill Moss with Bleach , this is true.
The problem with Moss is the conditions that caused it are still there so a Bleach application will need to be done nearly annually depending on the environment.
Using Penta or especially a copper salt like Copper Green will be a longer term fix.
Allowing the Moss to stay on the shingles will rapidly rot the ends off ,thereby ensuring that the next House Inspector will earn his fee. ;-))
One caveat I did not address in the previous post, do not let the chemicals get on your shrubs,plantings etc.
FredD
Fred's right.....
>None of mentioned that whatever you put on the shingles will likely have a affect on whatever is planted below.
Anything that kills the moss is likely to damage or kill the plantings below. If they are valuable, it would be a good idea to cover them.
We still don't know if the roofing is asphalt shingle or wood shakes. Fred thought it was shakes and mentioned rot. Since you said shingles I was thinking asphalt.
If you power wash a shake roof that is beginning to rot, it will "reveal" the ones that are rotting, by blasting them away. Powerwashing can ruin aging asphalt shingles by washing the granules off them. I'm guessing about the aging part also, but locally it takes about five years for the algae/fungi stain to show up on asphalt shingles and about ten years for the rot to exhibit itself on shakes.
Be Careful.
Don Orr
>I used a commercially available product from Lowe's specifically made for this problem. It connects directly to a garden hose and sprays on easily. It killed the moss and lichen that had started growing on our roof. It is supposed to be safe for other plants. It worked very well. Sorry, but I can't remember the name right now. It was in the section with weed killers and such.
Ed Mulligan, Cape Cod
>I'm very satisfied with Wash-Safe Industries products. Their roof wash is hydrogen peroxide. Safe for plants, non-bleaching to roof, siding etc. They powerwashed the plant life off and then put on a zinc strip to keep the stuff from regrowing. You can buy the stuff on their web site.
I've also used their deck wash. Very effective on dirt and mildew with a little brush effort and no damage to the wood surface.
