We value your privacy.
>I had the luxury of removing the carpet in one room of my house where I tried running screws through the floor sheathing into the joists. For some reason, I had very little luck at eliminating the all the squeaks.
However, a few years ago, my son had some similar squeaks in his kitchen and family room where we had access to the area below. What I did was make up a bunch of pieces of 1x4 pine with a length slightly less than the depth of his joists. At the ends, I drilled two pocket holes with a Kreg jig. I also predrilled some pilot holes straight through the wood pieces for attaching to the joists with deck screws. We went into the basement and determined where the squeaks were located. Put a little glue on the face of the 1x4 piece and screwed it to the joist, keeping it slightly (2-3 business cards) away from the underside of the floor boards. After the glue had set (about 45 minutes), we had the girls stand over the squeaky areas and we ran the pocket screws up into the floor. Worked like a charm. No more squeaks.
I've heard of metal brackets that sort of do the same thing, but if you have a Kreg jig, I'd go with that approach.
>I've had good luck fixing them on various floors, but have not had to tackle the vinyl. I would take a hammer and pound from above to find the joist under the floor. Make a straight cut along a pattern line thru the linoleum. Open it up just a shade. Now, go to the local borg and get small head drywall type screws. You can't miss them. They look like a tan deck screw, but the head is very much smaller than the ones you normally use. They are square drive screws. Drive the screw in between the slit in the floor and make sure it's below flush to the wood. Now glue back over the slits and put a large weight on it to help seal it shut.
If you can get at it from under the floor, you can just use a pocket type screw in the joist with a Kreg jig, you don't need a secondary block for a couple of pockets in the joist. If it's a t-joist, it's already set up to be able to drive a screw home. You're better to drill out the joist hole to be able to pull the floor down. If you don't have a Kreg jig, this is the excuse you've been waiting for.
If you still are concerned about using screws. Just cut a small hole in a liquid nails tip and pressure as much between the joist and the floor as you can. Don't have anyone stand on it as that will just take up the gap you're trying to fill.
>One thing that I have found is that it does work to screw the floor down if you can take out the carpet, but you also have to remove all of the nails. A lot of the squeaks are the nails moving in their holes and if they are not removed, the squeaks come back. No nails, no squeaks.
>Often the underlayment rather then the subfloor is the culprit making the squeak under the Vinyl.
After your try the easy approach for subfloor squeaks and you still have them , it probably is better to have the squeak then risk damage to the vinyl.
Of course your friend would have a good excuse for new vinyl. ;-))
>Went this morning and looked at the situation. The house is about a year old and has 2 x 10 yellow pine joists. There is a crawl space.
Most of the squeaks are around interior walls. Down a hall and beside a bathroom and under the wing wall at the refrigerator.
In the areas where there is carpet I am thinking I will pull back the carpet and drive screws through the floor into the joists on both sides of the wall. Then, from the crawl space, drive screws up into the bottom plate of the wall. In the kitchen, drive screws up into the bottom of the wall. I may also "caulk" both sides of the joists with liquid nails.
I thought about the Kreg jug I deal and I have the little one that can be clamped to the wood, but I couldn't figure how to clamp it to the top edge of the joist. The clamp doesn't have deep enough jaws. The additional blocks sound like a winner.
There is vinyl block tile on the kitchen floor. Anybody had good luck lifting the tile and putting it back down?
>Barry, If, like you say, most squeaks are close to interior walls, I've found that the wall plates often need to be secured better. Your idea of driving screws up from below should work if that's the case. George
>If this is happening around interior walls, the floor is probably moving away from the wall baseplate and that's the nails that are squeaking. The wall is a pretty rigid structural member once it's faced with sheetrock. I've seen this happen a number of times near pocket doors where there's not much to nail the base mold to. People try to toe nail the base mold into the floor and those fasteners invariably squeak. You can usually see them move if you look in the pocket door opening.
you can lift the tile nearly instantly with a block of Dry Ice, a little smaller then the tile.
Any problem associated with this method would be getting the tile glued back to the original level.. Might have to use a scraper and get rid of the old adhesive which the Dry Ice can help you with.
I had the same problem in my son's house. From the basement I screwed up into the wall base plate. That solved the problem. I would suggest trying this solution before you do anything on the floor above.
