Re: Bandsaw maintenance question
ThomD
>WD40 is the 40th water displacement oil formula the company came up with when trying to meet a contract. As all have said, no place in bearings. Bearings are either sealed, in which case you will see two rings of metal with a plate between them (the dust shield). In theory that shield is there to stop the grease from exiting under fan pressure, not so much to stop stuff getting in. This is one of those political arguments in the bike field where people put stock in sealed bearings to keep water out. Anywho, the other option is they are serviceable, repackable, greaseable. These could have grease cups, or zirc fittings for the grease. Or some obvious means of accessing them, even if the required wrench is unusual. There are also plain bearing, just a shaft in some kind of metal, these required the correct oil to be used constantly.
Sometimes a new machine will have bearing problems fairly directly, if the sealed bearings used are junk. Bearing replacement may get you a machine good for a 100 years.
