Help Cutting Compound Angles
Mark Meier (Ann Arbor, MI)
>I'm building some stands to roll around the studio while sculpting (clay). Here's the design. There are three legs which taper outward from top to bottom.
Stands1
I've built the easy stuff... thanks to Ed Mulligan's response to this post: Easy Way of Cutting a Perfect Hexagon?. Thanks, Ed!
Stands4
Now I need to make the bases. In a pure side view the leg is at an angle of 12 degrees from vertical.
The rails join the legs to form triangles in plan. So the angles on the ends of the rails are 30 degrees. However I think that's affected by the outward taper of the legs. But this is what I'm unsure about.
Stands3
I've never cut compound angles before so I'm not sure if I can really use 12 and 30 degrees or if they combine in some way that changes them. Does anyone have a recommendation for a method of calculating and cutting these accurately?
I can use either the table saw or a sliding compound mitre saw.
Thanks in advance for any help!
Mark
Re: Help Cutting Compound Angles
Re: Help Cutting Compound Angles *LINK*
>Compound Miter spreadsheet has worked for me.
WoodCentral BP Articles and downloads
Michael Bush
>If anything ever called for mocking up with scrap before making the cuts that count, that does.
John McGaw
>Try this as a starting point. My program has generally been quite accurate just as long as the input is the style that it expects.
Look at it this way...
>You can't cut that angle with a table or compound miter saw without some sort of fixture. What I would do is make a fixture to hold the rail such that a straight 90� chop cut will cut the compound bevel (assuming your chop saw has a big enough blade to plunge through the height of your rails).
To make the fixture, you need to know the tilt angle of the rail, which will be some trigonometric function of the 12� leg angle (math jocks, help me here -- I don't want to have to figure out the trig, though I've done it many times). Then find a 3x4 or something substantial to make the fixture out of. Swing the CMS angle 30� to the left and tilt the saw's bevel angle to the actual tilt angle of the rail. Cut off your 3x4 at this angle. Make a mirror image fixture for the other side of the blade.
Now, all you have to do is stand your rail stock against the cut edge of your fixture(s) and make a 90� cut. There isn't going to be much room to hold the rail to the fixture firmly, so you might want to screw a 1x4 to the face of the fixture to give you something you can clamp the rails to.
Ellis Walentine, Host
Fred Davis
>Unless I am missing something , I don't see any problem with cutting the rails on a Tablesaw.
Tilt the blade to 30 degrees and adjust the mitre fence to 12 or whatever the leg angle is and try it on scrap.
FredD
Ed Mulligan, Cape Cod MA
>Hey Mark,
Glad my hexagon post was helpful. I'm delighted to see your progress so far on your benches.
Steve Brown wrote an article in FWW #143 about using a setup block to cut compound tenons. Steve's method uses NO MATH!! I'm away from my collection of back issues so I'm going from memory but I think it would apply to your question. Maybe not. I won't have a chance to look at it until next week. Proceed with caution :)
>Thanks for all the responses everyone. I'm picking up some poplar later today to make a test base. I'm going to try using the angles from John's program and see how that goes.
I'll post some pics after I've succeeded.
Mark
