Re: Anybody check out the Cyclones on Ebay?
Alan in Little Washington (NC)
>There have been a number of threads about those cyclones on various forums.
They appear to be well constructed, but are NOT well designed nor as efficient separating the dust as one built using Bill Pentz's design and many commercial units. I can't say for sure but they appear to use the old Wood Magazine design. They do not have optimal cylinder and cone dimensions, do not have slanted inlets, do not have a spiral inlet ramp, and in fact the last I heard had no neutral vane whatsoever. All of these are features of a well designed cyclone. When I queried the seller about the absence of a neutral vane his response was akin to "don't need one of those vane things, whatever they are." If some of these terms are unfamiliar to you, check out Bill Pentz's web site. I suspect the seller is a metal bender and not an engineer. I base this on the design and his comments about arbitrarily changing inlet and outlet sizes.
Will it work, to some degree, yes, it will separate out the chips, but based on the design may have a hard time with fine particles, and may add resistance and reduce overall collection at the tool. Are there much better designs out there- yes, MUCH better. Is it cheap? Sort of, when compared to most cyclone only designs (remember you are getting the cyclone only no motor/blower unit, no filter, no stand, etc.,) but you get what you pay for. They are MUCH more expensive than building one yourself from 26 ga. sheet metal and some MDF (about $65) using the Pentz design.
