Bandsaw Wheel Tires
Bandsaw Wheel Tires
Bandsaw Wheel Tires
Ken Oakley-Sunny St. Cloud,Fla
>My 12 year old Delta 14" bandsaw is in need of new tires on the wheels. Need recommendations as the type, source, helpful installations tips, etc. Never did it before so I am a virgin,(when it comes to bandsaw tires)
Re: Bandsaw Wheel Tires
ebd
ebd
>I got the urethane ones from Woodcraft. They were a bitch to install untill I got it figured out but are fabulous once on the machine.
First tip - take the wheels off the saw.
Second tip - have some heat resistant gloves handy - don't have to be too heavy.
Third tip - have a bicycle tire removing tool or a piece of hard, flexible, strong plastic handy - nothing brittle, flexible is key
Fourth tip - have a large volume of boiling water handy
After that it's just turn the fire off under the water. Put the tires into the very hot water for a while. Put the gloves on, take a tire out and stretch it over the wheel. Use the bike tire tool or plastic as a lever if you need to. Once the tires are on, put the wheels back on the saw, install a blade and adjust to get it running true. Done. They will last for a long, long time.
Michael Bush
>Same saw, about the same vintage; I was speechless when I turned the saw on and the upper tire completely disintegrated. At first I had no idea what had happened. I got on the orange urethan tires without any tools except the gloves and the hot water. The bike tire tool is a great idea, though.
I also replaced the bearings while I had the wheels off the saw, because they were starting to roar.
ThomD
>If you want to glue the tires on, a simple method is to get some double sided tape and apply it to the wheel, then find a solvent that makes it all oily, like some paint thinner. Apply enough to make the tape slippery, and then stretch the tire on. leave overnight until the solvent evaporates, and your tire will be glue to the bandsaw, yet you won't need to mill it to shape.
pdf from OWWM.com *LINK*
Tom Sontag - St. Louis
>This provides a good summary of the process:
click here
Alexander Grigoriev
>Another helpful tip - after you take it out of the boling water, before installation, just stretch it with hands as much as you can.
