Wood question for the Aussies....
John in NM
>Is lyptus going to be a good match for "coachwood"? Having only seen pictures of coachwood, I don't really have a good idea what the grain looks like, though the color looks similar to the lyptus scraps I have.
Thanks!
Re: Wood question for the Aussies....
What's lyptus?
Gerry In North Surrey
>Is it something like doug fir?
Gerry, who's confused...........
Lyptus *LINK*
>Lyptus is a trade name for a breed of eucalyptus grown on plantations in Brazil. It is not an Australian wood per se. As for coachwood, I'd like to hear more about it. Got pictures?
If you want to see what Lyptus looks like, click the link below. It is very hard and tough. I wouldn't hesitate to use it for floors. I don't know about furniture, but I'd like to try it.
Lyptus gallery
I don't know a whole lot about it... *LINK*
John in NM
>The name coachwood is familiar to me, probably from reading in one of the various wood encyclopedias. I don't recall ever seeing it for sale here in the US (not at all surprising), so I'd also like to know how common it is in Australian use and how specifically the name is used in the Australian lumber trade.
As to my application, I've been asked to match a grip to the stock on an Australian surplus rifle, as far as I can research, the species is listed as "coachwood".
coachwood specs
More Lyptus info
Michael Dresdner
>I did an article on Lyptus, which is a trade name owned by Weyerhaeuser, in the Industry Interview segment of issue 220 of Woodworker's Journal eZine. Back issues are online.
In a nutshell, it is an exotic South American hardwood that is plentiful, beautiful, reasonably priced, dense, has excellent working properties, and perhaps most importantly, is more ecologically �green� than other exotics. Technically, Lyptus is a hybrid of Eucalyptus grandis and Eucalyptus urophylla and is similar to hickory or hard maple, stains remarkably well and evenly, and takes any sort of finish very well.
It is a plantation grown wood, planted on formerly cleared areas of Brazilian rain forest, so it not only acts as a crop wood, but also is reclaiming cleared land by replanting. It grows so fast that they can harvest and replant the trees in as little as 15 years.
Re: I don't know a whole lot about it...
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
>When I used some Lyptus several years ago, I remember the wood tended to come in two shades. One resembled cherry and one was closer to mahogany. The articles I read at the time said Lyptus was a good substitute for mahogany in color and grain. it is of course a hard, hard wood which led me to re-grinding my chisels so i could finish the piece I was working on. It worked well with power tools except for my planer knives and definitely is not something I would want to cut dovetails in with a chisel. But it does take a nice finish and is hard as all get out so it should be durable.
Roy Girolami
Apex, NC
Re: More Lyptus info
charlie belden
>"It is a plantation grown wood, planted on formerly cleared areas of Brazilian rain forest, so it not only acts as a crop wood, but also is reclaiming cleared land by replanting. It grows so fast that they can harvest and replant the trees in as little as 15 years. "
If you've lived in the tropics you probably are aware of how quickly the jungle reclaims open spaces - with indigenous species - if you let it. And the native animals and insects return - if you let them. Takes a lot of effort to stop this process.
Single species plantations can, and are, stopping the natural reforestation - and the return of the local animals and insects. Plantations change the ecology where they exist.
When you think "plantation" you have to also think - chemicals 0 that aren't normally found in the rain forest - fertilizers and insecticides. Add a fair amount of rainfall - and some of those chemicals get into rivers and streams - and dispersed over a much larger area than just the plantation's land.
The other thing that isn't mentioned when talking about these tree plantations is their much lower CO2 absorption per acre than rainforest trees'.
It's a classic dilema - increase supply (and try to increase demand) - or - reduce the demand, recycle existing materials and look for alternative materials?
Bart Goldberg
Re: Lyptus
Bart Goldberg
>Last time I was at Bally Block (which was over 2 years ago) - I noticed that they are now making butcher block counter tops from this wood in addition to the ususal hard maple. I did grab a few scraps to take home while I was there. It is very hard, slight reddish in its unfinished state and a bit stringy I recall.
Bart
andrew f in australia
>Lyptus is a hybrid that's close to our Rose Gum (a.k.a Flooded Gum) as the main hybrid. It's a strong timber that we use in staircases, primarily. There's gum veins in Rose Gum that I believe have been bred out in the hybridised version.
Coachwood is a really fine timber that works well and takes a polish beautifully. It's not a eucalypt. (hence, used for coaches in the 19th C.) It carves well and takes polish well, used a lot for rifle butts in the past, now not a common species.
TIPS ON WORKING EUCALYPT
(1) It's a species with pores, needs filling as part of finish.
(2) The genus as a whole is brittle cross-grain. If you're cutting out housings or trenches, you'd be well advised to score the grain with a marking gauge or knife before hitting the thing with a router. You will get blowout/spelching at the edges otherwise that will ruin your work.
(3) It's fairly hard on the international scale of timbers, prepare for blunted tools at a semi-regular rate.
Cheers,
Andrew F
Coachwood
>Hi Ellis.
Coachwood is one of our better furniture timbers, used predominantly in rifle butts as it carves beautifully.
Now not a common species (overharvested.
Very fine grained, even grained, a lot of figure a/c of soft end grain, harder 'side' grain. Slight ripples are really accentuated.
I made something out of it at school. Now not a timber you see often.
Cheers,
Andrew F
