OT Anybody Know Compact Flourescents?
Kneale Brownson..Back enjoying CO snow
>All the compact flourescents I've looked at in stores have the warning they are not for use in fixtures operated by a dimmer.
Is it OK to use them that way anyway if you don't try to "dim" the light?
Re: OT Anybody Know Compact Flourescents?
They do make "Dimmable" Fluorescents. *LINK*
>I have seen and used them. I do have three way fluorescent bulbs. I have replaced some of the bulbs in the church with dimmable CFLs. I don't know how long they will last, but so far so good.
Here is one source.
Dimmable Flurorescent Bulbs
Dan Donaldson
>If you want to do that, why not just change the dimmer for a regular switch and there would not be any risk.
Tony - Memphis
>My house is full of them. Although the offerings in the big bixes are getting better, I found that I could get a much better selection online. I wanted bulbs that looked like an incandescant in color. That was important to us. I was able to buy by coor temp., size, bulb type, etc. I have a couple of three ways too. I haven't tried the dimmer type yet. I buy from these folks..
http://www.lightbulbsdirect.com/
I got one bad one and they replaced it immediately without any hesitation.
I'm looking into LED's now. We've replaced most of our bulbs with the CFL's. I can't tell a difference in our bill, but I can't help but believe it has helped. Not an ROI situation, but.. One place I know they had to have helped is the chain of 6 or seven spots we have in our kitchen. They were 75W each. Now they are 1/4 of that.
Tony
Jay
>If you are not going to dim them, change the dimmer to a switch. If you still want to dim them there are dimmable CFL's now. Just an added note where NOT to use CFL's, do not install them on electronic timers. The little electronic ones that control porch lights, coach lights etc. They take the place of a switch at the front door. These electronic timers allow a tiny leakage of current through to the bulb, just enough to excite the starter in the CFL and it will flicker ever so slightly. About 1 day later bulb is shot! Found out the hard way (twice!) until I got the info from the bulb manufacturer.
Jay
