lights out
lights out
lights out
Ronald
>http://images.lowes.com/product/converted/842235/842235920155md.jpg I put these lights in a year ago and ever since i put them in they work on and off. Is this the way they are supposed to work. If they get to hot do they kick off, and when they cool off come back on? The problem is that i can leave them off for an hour or more and some will come back on an some not. Thinking about replacing them. Can anyone shine some light on this???? Thank you for your help if you can.
Re: lights out
Re: lights out
>Don't know specifically, but recessed lights are rated for certain sized/watts bulbs. Look inside the fixture at the label and see what it is rated for and check that against the bulbs. The fixtures may have an over heat protection feature that cuts out when they over heat. Try smaller, cooler bulbs.
Re: lights out
Re: lights out
Ronald
>It says 50 watt and that's what i use. Thing is they can be off for 2 or 3 hours and they still will not light. I think this is maybe bad light or something. Going back to Lowes to talk with them. thanks for the help!
Re: lights out
Re: lights out
Jay
>Newer can lights all have thermal cutoff switches in them. What you are describing is typical of the cutoff going off from too much heat generated by people using 100W bulbs in cans rated for 60. If you are using the proper bulb,proper insulation rating, etc., then it is a faulty sensor, they are notoriously cheap and fail often.
Good Luck,
Jay
