How Dumb Can I Get?
>Good Afternoon Friends,
SWMBO decided to utilize the granite left over from our counter tops for a new kitchen table top. Dumbo here was to fabricate the legs and frame it would set upon, and have it ready by delivery date. The kitchen has already been templated, and the granite will be delivered and fitted this coming week.
I went to Hearne Hardwood and bought 12/4 hard maple for the legs. My #3 son helped me rip it to 28"long, 2 3/4"sq blanks. I laid out the mortices with care, touched up my 1/2" chisels and chucked one of them into my Shop Fox morticer. A practise plunge went well enough to make Norm Abram proud of the set up. I set the depth stop to achieve a 1 1/2" depth by stacking two 3/4" offcuts as a spacer. Then put the first leg in the cross slide vise and carefully aligned the chisel to the layout lines. Flipped on the machine, Pulled the handle. It hardly moved. Shut off the machine three times to adjust and readjust the central bit to the chisel. It still wouldn't move. then I remembered that I was doing it in hard maple with a 1/2" bit. So, I really pulled on the handle. Hard. BANG!!! Both my #3 son and his helper heard the noise coming from the Morticer and from me. They thought I had been hurt--seriously because of the unabreviated expressions of outrage coming from me. It seems I had forgotten to remove the spacer. I sheered off the allan bolt holding the pinion gear to the head's axel. Luckily, no other damage except lost time. I feel cheated. All that anger and emotion should have been worth more than the $0.45 it cost for a replacement bolt, a hex head this time.
George
