Moulder Set Up
Moulder Set Up
Moulder Set Up
Guest
>I've just purchased a Grizzly planer moulder and am in the process of installing the moulding knives which are open ended knives that measure 2 3/4 inches in length and 1/4 inch thick. My question to you knowledgable folk is: Should these knives have come with there own gibs (as my manual suggests)? Or can I make this work somehow with the factory gibs which are only two inches in lenth and allow a thickness of 1/8 with the planer knives left in?
Could I safely support a 2 3/4 moulder knife with a 2 inch gib? I've heard tell that this is possible, but have my doubts.
Thanks all.
Ben
Re: Moulder Set Up
Please Pardon me, but
Robert R. Clough - Thorncraft
>it is Molder, not Moulder. You are making a "mold" not making anything "Mouldy". Cheese, Bread, and Grout around the tub get mouldy.
Re: Moulder Set Up
Re: Please Pardon me, but
John Luke
>Either moulder or molder is acceptable.
Re: Moulder Set Up
Planer moulder is British term for "jointer" *LINK*
Nathan
>Judging from the Felder U.K. site, it's also referred to as just plain planer, without the moulder part.
Other U.K. terminology:
spindle moulder = shaper
thicknesser = planer
planer/thicknesser = J/P combo
I imagine the most confusing is the British planer vs. American planer difference.
Ben: you might also try a U.K. woodworking discussion board such as UKW (see link).
UK Workshop forums
Re: Moulder Set Up
GolfSteve in Calgary
>Depends where you live. I would have spelled it "moulder".
I would have understood molder, but it does not look right.
However, I cannot answer our Guest's question (who is perhaps a neighbour of ours).
Cheers,
Steven
Re: Moulder Set Up
Re: Moulder Set Up
John Luke
>Short answer is, yes it would be possible to use a 2" gib with a
2 3/4" knife.
It would depend on the profile of the knives if the 3/8" on each end are unsupported with gib would affect the cut.
Several light cuts beter than one cut.
Tighten the heck out of the gib screws.
Thanks all.
Re: Moulder Set Up
Re: Moulder Set Up
Bill White
>Semantics.
Now to the question......
If in doubt, call Grizz tech support. Tighten the gib screws well, but take care not to overtighten.
Bill
Re: Moulder Set Up
Re: Moulder Set Up
Guest
>John, Bill,
Thanks for your responses. My initial concern was chatter or knife breakage on the unsupported portion of the knife. Hopefully light cuts won't overload the knife, we'll see.
I'll try contacting Grizzly and the knife manufacturer, for their input as well
Thanks again for you input.
I'll update with results
Ben
