Spraying Waterbased Finishes
Chuck Jurvelin
>I have a Binks No.7 siphon-feed gun and also a Binks HVLP gravity-feed gun and complete spraying facilities. I have sprayed lacquer and other solvent-based finishes for years with great success. I have yet to find a water-based finish that sprays well and I am looking for feedback as to finishes and/or spray equipment. I have a large air compressor, and do not want to switch to a turbine type. Iwould appreciate any advice.
Re: Spraying Waterbased Finishes
Re: Spraying Waterbased Finishes *LINK*
Jim G
>I've had good results with the Target EMTECH 8000 from Homestead Finishing. Much better than any other brands from hardware/paint/big box stores.
jim
http://www.homesteadfinishingproducts.com/htdocs/t
mdclor
>In addition to homesteadfinishingproducts.com, look at targetcoatings.com. There is wealth of info to be found at both sites and they are both very friendly forums.
HTH,
Merle
pecker
>I have used Hydrocote, Enduro, Crystalac, and Target EM6000.
The target was the best as far as how it flows out, and it seemed to clog the tip of the gun less also.
I don't care for the appearance of the Satin EM6000 though...it has a whitish cast after drying. The Gloss and SemiGloss are nice, however.
>Target (Oxford) is great stuff and handles very well, especially if you've got the experience to use the SA-5 retarder. The USL is unique in it's 100% burn-in capability, so it handles just like solvent lacquer.
I have also had great results with the General Enduro Super clear Poly, both with and without crosslinker added. In fact, if you use these, you'll want to take extra care to clean your surface prior to application as you'll be tempted to leave things "off-the-gun". Attached and following are two examples. Attached in a rubbed out cherry sofa table and following is an off-the-gun coffee table in ash using cross-linked Enduro.
All of this stuff is for HVLP. Noted difference from solvent lacquer is to not "double-hit" each coat at 90�, and you do need to wait an hour or two between coats to allow the film to firm up.
Lastly, keep checking your fluid tip for build-up which will affect your fan. I use both a gravity-feed and a pressure pot. Siphon feed gun has not done nearly as well.
No. 2
Chuck Jurvelin
>Thank you for the input. I ordered a gallon of EM TECH 6000 directly from Targetcoatings.com. With the discount code and free shipping, it was only $35.20. I hope I like it, because the price is right and I go through quite a bit of finishing material. THANKS AGAIN!
Don't Be Bashful
>You can call Jeff Weiss (Owner/Pres. of Target) with questions.
Bob Boswood
>Just finished a kitchen cabinet job spraying water based sherwin williams with a gravity fed hvlp gun, large compressor. Old painter gave me a tip I tried and it worked great. Thin the product 1 to 4 ratio with water. Place in a container of some kind and heat it to 100 degrees in a crock pot filled with water low setting worked on mine. The viscosity was perfect. I was able to spray three coats a day twice. This is one tip I will put in my bag of tricks to remember.
Bob in AK.
Fred Davis
>Why trade "great success " for something somewhat less?
FredD
Joe Dusel (Vista, CA)
>Target Coatings make good products, but getting them in my area is a problem. The product that I just started using is Valspar's Zenith Pre-Cat WB Lacquer. It goes on nice, it does not need to be thinned, it levels out great and it looks terrific. I have used Target, Mohawk, ML Campbell Aqualente, Gemini, Enduro, ApolloCoat and others; but I think this new Valspar Zenith is going to be my new favorite.
Joe
