Air brushing
Air brushing
Air brushing
Joe Pack
>I plan to do a bit of turning and flat work where I would like to do a bit of painting, but want to avoid brush marks. Air brushing seems to be the thing to do, particularly where I want to gradually shade colors.
If I do this, I need to buy an airbrush setup, including small compressor. I have seen several ranging from the Harbor Freight set to setups costing several hundred dollars. I am not going to do hours and hours of this, but I also don't want to waste my money on something that is gross overkill for what I will use it for; I don't want to regret buying "cheap" and finding out I need something more, and I don't want to buy a Cadillac when a Chevrolet will do just fine.
I would like to be able to end up with both flat and gloss finishes, depending on the object. And I might even want to spray a bit of water-based poly or such if that can be done with an airbrush.
Any advice to offer on compressors, airbrushes, needles, etc.?
Re: Air brushing
Clint Searl
Re: Air brushing
Clint Searl
>Even high end air brushes are finicky. They are fussy about what they'll spray, and tend to clog easily. For fine work, I use a little conventional gravity feed SATA detail gun with nothing but solvent lacquer. It's easy to adjust the pattern and pressure for control.
Clint
Re: Air brushing
Badger or Paasc at Michael's
>We picked up one at Michael's for half price right after the holiday a few years back.
They also sell compressed air in an aersole can, which works well for small tasks. At one point I just got a 8 gallon portable/auxiliary air tank, filled it with air from my large compressor in the garage and brought it to the art room when my wife paints.
Happy Woodworking!
Re: Air brushing
Re: Air brushing
Bill Earl
>I have a few Badger air brushes. The Omni is probably the most versatile of the bunch. I've sprayed everything from inks to acrylics with it.
Mostly I run it off my 2 Hp compressor with an extra reguator and filter. It will go quite a while off a small pressure tank. I know some who power them with a spare tire.
DixieArt has a good selection and prices (www.dixieart.com)
Re: Air brushing
Re: Air brushing
Fred Davis
>In the years long gone now that I did serious Leather work , I used a Paasch and Binks air brush brands.
The Paasch cost moe , but was well wprth it.
They routinely handle leather dyes which are like ink, right up Lacquer.
20 to 30 PSI is all the pressure they need.
For fading a color from light to dark in small areas, it is the tool of choice.
FredD
